VisualRF Plan Issues
  • 1.  VisualRF Plan Issues
    Posted Feb 08, 2014 12:09 PM
    I am currently working with VisualRF Plan. I have one computer that several versions of VisualRF Plan have ran flawlessly on (lower-end HP workstation w/ Windows7 and 4GB of ram). I have also attempted to install VisualRF Plan on my Parallels virtual Windows7 PC and also on a Dell XPS laptop that has Windows 8.1. On these two computers I can create the campus, buildings, etc. just fine. When I import the floorplan, the import is successful but once I click save and close the floorplan never reappears for me to add APs, draw walls, etc. VisualRF Plan simply returns to the screen with the loading animation and never shows the floorplan. if you click the refresh button, it states that it cannot display the floorplan.
    The floorplan file type that I am using is JPG and PNG, although I have tried several other formats as well with the same results.
    I have adjusted the IE security settings to virtually nothing. I have ensured the Windows has been updated on both PCs and that I am also running the latest version of VisualRF Plan (which works fine on the first computer that I mentioned).
    Would anyone happen to have an idea as to how I could start troubleshooting these issues?
    Thanks!
  • 2.  RE: VisualRF Plan Issues
    Posted Feb 09, 2014 03:33 PM
    Update:
    I have tried to uninstall/reinstall VisualRF Plan on the virtual Win7 and also the Win8.1 laptop. Each device I followed the same procedure as follows:
    1. Uninstall VisualRF Plan
    2. Reboot PC
    3. Install VisualRF Plan
    This made no difference, and the errors/timeouts still exist.
    Upon further reading in the VisualRF Data directory I noticed a file called  VisualRF.txt. The contents contain several errors seeming to be related to Java. (Shown below:)
    2014-02-08 09:20:32,354 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?108873
    2014-02-08 09:20:32,355 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/getUserPref
    2014-02-08 09:20:32,602 WARN erPreference com.airwave.svg.UserPreferenceServiceImpl loading default user preference from /user_preference_default.xml
    2014-02-08 09:20:32,627 WARN erPreference com.airwave.svg.UserPreferenceServiceImpl loaded default preference.
    2014-02-08 09:20:32,662 WARN erPreference com.airwave.svg.UserPreferenceServiceImpl Loaded customized user preference. Count = 1
    2014-02-08 09:20:34,088 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/access_level.xml
    2014-02-08 09:20:34,089 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/setUserPref?prefName=display_24GHz&value=true
    2014-02-08 09:20:34,141 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/setUserPref?prefName=display_5GHz&value=true
    2014-02-08 09:20:34,142 WARN HTTP[3] com.airwave.svg.init.StandaloneServerRequestHandler Attempt to load sa_dummy//swf/overlay_colors.xml
    2014-02-08 09:20:34,142 ERROR HTTP[3] com.airwave.svg.init.StandaloneServerRequestHandler Do not know how to handle: /swf/overlay_colors.xml
    2014-02-08 09:20:34,143 WARN HTTP[6] com.airwave.svg.init.StandaloneServerRequestHandler Attempt to load sa_dummy//swf/tile_colors.xml
    2014-02-08 09:20:34,143 ERROR HTTP[6] com.airwave.svg.init.StandaloneServerRequestHandler Do not know how to handle: /swf/tile_colors.xml
    2014-02-08 09:20:34,149 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/cluster.xml?id=undefined&images=1
    2014-02-08 09:20:35,239 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?images=1
    2014-02-08 09:20:35,329 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?17267
    2014-02-08 09:20:41,781 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?campus_id=77abb85f-c8a6-4682-865e-38fc22c53b82&sites=1&buildings=1
    2014-02-08 09:20:42,964 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/remove_campuses
    2014-02-08 09:20:43,142 WARN HTTP[5] com.airwave.svg.SiteCoordinatorImpl Plan datarate radius multiplier is 1.0
    2014-02-08 09:20:43,142 WARN HTTP[5] com.airwave.svg.SiteCoordinatorImpl Plan signal radius multiplier is 1.0
    2014-02-08 09:20:43,142 WARN HTTP[5] com.airwave.svg.SiteCoordinatorImpl Plan sensor radius multiplier is 1.0
    2014-02-08 09:20:43,142 WARN HTTP[5] com.airwave.svg.SiteCoordinatorImpl Plan sensor data rate is 6
    2014-02-08 09:20:51,148 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/add_campuses
    2014-02-08 09:20:51,185 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/add_campuses
    2014-02-08 09:20:51,285 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/access_level.xml
    2014-02-08 09:20:51,327 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?images=1
    2014-02-08 09:20:51,373 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?308431
    2014-02-08 09:20:53,928 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/add_campuses
    2014-02-08 09:20:53,951 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/access_level.xml
    2014-02-08 09:20:53,984 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?images=1
    2014-02-08 09:20:54,032 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?478505
    2014-02-08 09:20:55,344 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?campus_id=0f970a3f-a5c3-4c22-93ae-297a73ebf0bb&buildings=1&images=1
    2014-02-08 09:20:55,397 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?808188
    2014-02-08 09:20:56,783 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?images=1
    2014-02-08 09:21:02,469 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?campus_id=0f970a3f-a5c3-4c22-93ae-297a73ebf0bb&buildings=1&images=1
    2014-02-08 09:21:02,487 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/add_buildings
    2014-02-08 09:21:06,353 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/add_buildings
    2014-02-08 09:21:06,385 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/access_level.xml
    2014-02-08 09:21:06,424 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?campus_id=0f970a3f-a5c3-4c22-93ae-297a73ebf0bb&buildings=1&images=1
    2014-02-08 09:21:06,480 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?754410
    2014-02-08 09:21:07,420 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/building.xml?building_id=e8e0c097-f1e8-4539-b043-05a7f8a4cd09&sites=1&images=1
    2014-02-08 09:21:07,479 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?111194
    2014-02-08 09:21:09,175 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/newTask?type=image&defeatcache=3100440
    2014-02-08 09:21:21,150 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/uploadTaskResourceRedirect
    2014-02-08 09:21:21,814 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/campus.xml?buildings=1&sites=1&defeatcache0.4157927371561527
    2014-02-08 09:21:21,814 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/moveTask?taskId=cabc24b6-42a9-49ef-b631-3efc4bc5ed8d&defeatcache=0.7242063493467867
    2014-02-08 09:21:22,105 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/getTaskResult?taskId=cabc24b6-42a9-49ef-b631-3efc4bc5ed8d&defeatcache=92274014
    2014-02-08 09:21:22,106 WARN HTTP[4] com.airwave.svg.itaskimpl.ImageTask Resource Input Name List inputName: file
    2014-02-08 09:21:22,106 WARN HTTP[4] com.airwave.svg.itaskimpl.ImageTask {file=com.airwave.svg.itaskimpl.AbstractITask$ResourceFile@2ff57c}
    2014-02-08 09:21:54,598 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/updateTaskRequest
    2014-02-08 09:21:54,630 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/moveTask?taskId=cabc24b6-42a9-49ef-b631-3efc4bc5ed8d&defeatcache=0.7324462090618908
    2014-02-08 09:21:54,681 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/addSite
    2014-02-08 09:21:54,993 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/getUserPref
    2014-02-08 09:21:54,993 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?78292
    2014-02-08 09:21:56,530 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/access_level.xml
    2014-02-08 09:21:56,530 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/setUserPref?prefName=display_24GHz&value=true
    2014-02-08 09:21:56,537 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/setUserPref?prefName=display_5GHz&value=true
    2014-02-08 09:21:56,548 WARN HTTP[2] com.airwave.svg.init.StandaloneServerRequestHandler Attempt to load sa_dummy//swf/overlay_colors.xml
    2014-02-08 09:21:56,548 ERROR HTTP[2] com.airwave.svg.init.StandaloneServerRequestHandler Do not know how to handle: /swf/overlay_colors.xml
    2014-02-08 09:21:56,549 WARN HTTP[3] com.airwave.svg.init.StandaloneServerRequestHandler Attempt to load sa_dummy//swf/tile_colors.xml
    2014-02-08 09:21:56,549 ERROR HTTP[3] com.airwave.svg.init.StandaloneServerRequestHandler Do not know how to handle: /swf/tile_colors.xml
    2014-02-08 09:21:56,668 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/cluster.xml?id=undefined&images=1
    2014-02-08 09:21:56,737 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/site.xml?site_id=854e726a-a9c7-4aeb-903e-31af8b3a9ef0&defeatcache=9067802&aps=1&clients=1&rogues=1&surveys=1&regions=1&walls=1&rfids=1&properties=1&sensors=1&detail=1&idf=1&rack=1&interferer=1
    2014-02-08 09:21:59,958 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?331146
    2014-02-08 09:21:59,958 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=116629
    2014-02-08 09:22:00,992 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=116629
    2014-02-08 09:22:02,026 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=116629
    2014-02-08 09:22:03,059 WARN HTTP[5] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=116629
    2014-02-08 09:22:27,103 ERROR HTTP[2] com.airwave.svg.init.StandaloneServerRequestHandler Exception sending resource: css/amp.css
    java.io.IOException: An existing connection was forcibly closed by the remote host at sun.nio.ch.SocketDispatcher.write0(Native Method) at sun.nio.ch.SocketDispatcher.write(Unknown Source) at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source) at sun.nio.ch.IOUtil.write(Unknown Source) at sun.nio.ch.SocketChannelImpl.write(Unknown Source) at sun.net.httpserver.Request$WriteStream.write(Unknown Source) at java.io.BufferedOutputStream.flushBuffer(Unknown Source) at java.io.BufferedOutputStream.flush(Unknown Source) at sun.net.httpserver.ExchangeImpl.sendResponseHeaders(Unknown Source) at sun.net.httpserver.HttpExchangeImpl.sendResponseHeaders(Unknown Source) at com.airwave.svg.init.StandaloneServerRequestHandler.handleResourceRequest(Unknown Source) at com.airwave.svg.init.StandaloneServerRequestHandler.run(Unknown Source) at com.airwave.svg.init.StandaloneLauncher$StandaloneDelegateHttpHandler.handle(Unknown Source) at com.sun.net.httpserver.Filter$Chain.doFilter(Unknown Source) at sun.net.httpserver.AuthFilter.doFilter(Unknown Source) at com.sun.net.httpserver.Filter$Chain.doFilter(Unknown Source) at sun.net.httpserver.ServerImpl$Exchange$LinkHandler.handle(Unknown Source) at com.sun.net.httpserver.Filter$Chain.doFilter(Unknown Source) at com.airwave.svg.init.StandaloneLauncher$ContextFilter.doFilter(Unknown Source) at com.sun.net.httpserver.Filter$Chain.doFilter(Unknown Source) at sun.net.httpserver.ServerImpl$Exchange.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.lang.Thread.run(Unknown Source) 2014-02-08 09:22:28,420 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?965950
    2014-02-08 09:22:28,421 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/getUserPref
    2014-02-08 09:22:28,827 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/access_level.xml
    2014-02-08 09:22:28,827 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/setUserPref?prefName=display_24GHz&value=true
    2014-02-08 09:22:28,838 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/setUserPref?prefName=display_5GHz&value=true
    2014-02-08 09:22:28,847 WARN HTTP[5] com.airwave.svg.init.StandaloneServerRequestHandler Attempt to load sa_dummy//swf/overlay_colors.xml
    2014-02-08 09:22:28,847 ERROR HTTP[5] com.airwave.svg.init.StandaloneServerRequestHandler Do not know how to handle: /swf/overlay_colors.xml
    2014-02-08 09:22:28,849 WARN HTTP[1] com.airwave.svg.init.StandaloneServerRequestHandler Attempt to load sa_dummy//swf/tile_colors.xml
    2014-02-08 09:22:28,850 ERROR HTTP[1] com.airwave.svg.init.StandaloneServerRequestHandler Do not know how to handle: /swf/tile_colors.xml
    2014-02-08 09:22:28,970 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/cluster.xml?id=undefined&images=1
    2014-02-08 09:22:29,033 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/site.xml?site_id=854e726a-a9c7-4aeb-903e-31af8b3a9ef0&defeatcache=6479009&aps=1&clients=1&rogues=1&surveys=1&regions=1&walls=1&rfids=1&properties=1&sensors=1&detail=1&idf=1&rack=1&interferer=1
    2014-02-08 09:22:29,127 WARN HTTP[3] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/visualrf_config.xml?616403
    2014-02-08 09:22:29,127 WARN HTTP[2] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=8328194
    2014-02-08 09:22:30,152 WARN HTTP[1] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=8328194
    2014-02-08 09:22:31,185 WARN HTTP[4] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=8328194
    2014-02-08 09:22:32,226 WARN HTTP[6] com.airwave.svg.init.StandaloneVisualRFRequestHandler RequestURI:/visualrf/data/854e726a-a9c7-4aeb-903e-31af8b3a9ef0/background.jpg?defeatcache=8328194
    2014-02-08 09:22:41,236 WARN Thread-10 com.airwave.svg.init.StandaloneLauncher VisualRF server shutting down
    2014-02-08 09:22:41,326 WARN erPreference com.airwave.svg.UserPreferenceServiceImpl storing user preference data
    2014-02-08 09:22:41,327 ERROR Inventory com.airwave.model.services.InventoryService persist threadpool size property
    java.io.FileNotFoundException: svg.properties (Access is denied) at java.io.FileOutputStream.open(Native Method) at java.io.FileOutputStream.<init>(Unknown Source) at java.io.FileOutputStream.<init>(Unknown Source) at com.airwave.core.PropertyServiceImpl.updatePropertiesFile(PropertyServiceImpl.java:151) at com.airwave.core.PropertyServiceImpl.setPropertyOverrides(PropertyServiceImpl.java:138) at com.airwave.core.PropertyServiceImpl.setPropertyOverrides(PropertyServiceImpl.java:125) at com.airwave.svg.InventoryServiceImpl.preShutdown(InventoryServiceImpl.java:525) at com.airwave.core.AbstractService.run(AbstractService.java:520) at java.lang.Thread.run(Unknown Source) 2014-02-08 09:22:41,327 WARN Database com.airwave.core.data.ConnectionManager shutting down derby database
    2014-02-08 09:22:41,329 ERROR Event com.airwave.core.EventDispatcherImpl persist threadpool size property
    java.io.FileNotFoundException: core.properties (Access is denied) at java.io.FileOutputStream.open(Native Method) at java.io.FileOutputStream.<init>(Unknown Source) at java.io.FileOutputStream.<init>(Unknown Source) at com.airwave.core.PropertyServiceImpl.updatePropertiesFile(PropertyServiceImpl.java:151) at com.airwave.core.PropertyServiceImpl.setPropertyOverrides(PropertyServiceImpl.java:138) at com.airwave.core.PropertyServiceImpl.setPropertyOverrides(PropertyServiceImpl.java:125) at com.airwave.core.EventDispatcherImpl.preShutdown(EventDispatcherImpl.java:56) at com.airwave.core.AbstractService.run(AbstractService.java:520) at java.lang.Thread.run(Unknown Source)
    These errors are all located around what the time entry would be for the last time I tried to execute VisualRF on this PC. The other PCs that I have tried to get VisualRF working on have also displayed the same results with different time stamps corresponding to when I have executed VisualRF Plan. There seems to be permissions errors in the logs, however I am logged in as Administrator and have also even explicitly applied NTFS permissions to all files (except system files) as full control.
    I have also tried to update/remove/reinstall JRE. Additionally, I have also tried using older versions of VisualRF Plan in which the installer gives me an error about a command line switch that is illegally used. (The thinking was to upgrade an older version in which the only computer that I have where VisualRF is working correctly on.)
  • 3.  RE: VisualRF Plan Issues
    Posted Mar 04, 2014 03:02 PM
    I had a similar issue that is now resolved. Try the following:
    Update Java
    Update Flash
    Uninstall 7.7
    Install 7.6 - test to make sure it works
    Uninstall 7.6
    Install 7.7 and test again.
    In Windows 8 you may need to run in compatibility mode I believe.
  • 4.  RE: VisualRF Plan Issues
    Posted Mar 04, 2014 03:03 PM
    Also with a virtual machine, you need to turn off sharing from your local machine to the VM.
  • 5.  RE: VisualRF Plan Issues
    Posted Mar 04, 2014 04:00 PM
    Was the install done using WinXP compatibility mode?
  • 6.  RE: VisualRF Plan Issues
    Posted Mar 05, 2014 01:38 PM
    I have this issue as well on both Win 7 and 8. I've tried running the installer in compatibility mode for XP SP3 and 7 and also with no compatibility.
    No luck. After importing a floorplan (either jpg or DWG), the application just spins.
  • 7.  RE: VisualRF Plan Issues
    Posted Mar 05, 2014 04:16 PM
    Did you try installing 7.6, uninstalling, and then 7.7? That worked for me after Java and Flash were up to date.
