Aruba Apps
last person joined: 12 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
VisualRF Plan not starting
  • 1.  VisualRF Plan not starting
    Posted Apr 05, 2017 09:51 AM
    VisualRF Plan was working fine on my laptop when suddenly I could no longer start the application. No errors show up that might indicate the underlying issue.. the application just doesn't start when I click its icon.
    My OS is Windows 8.1 and Google Chrome is my default browser.
    Appreciate if you can help me solve this issue.
  • 2.  RE: VisualRF Plan not starting
    MVP EXPERT
    Posted Apr 05, 2017 10:16 AM
    Which version are you running? In the later versions it is browser/Java based. If you are running v8 and above try the following. This happens on a frequent basis to myself and the below worked for me previously when there was issues and there has been no changes to my system....
    - Uninstall VisualRF
    - install the latest JAVA version and adobe flash player.
    - Delete temp %temp% folders and prefetch folder. Rebooted the PC.
    - Re-install VisualRF
  • 3.  RE: VisualRF Plan not starting
    Posted Apr 06, 2017 08:58 AM
    Thank you so much zalion0.. it worked!
  • 4.  RE: VisualRF Plan not starting
    MVP EXPERT
    Posted Apr 06, 2017 09:05 AM
    Glad to hear it! :D
  • 5.  RE: VisualRF Plan not starting
    Posted Mar 13, 2018 05:01 AM
    Hi Team,
    Ii was trying to open the VRF also its not opening also it is giving the below error.
  • 6.  RE: VisualRF Plan not starting
    Posted Mar 13, 2018 05:07 AM
    Even i tried uninstalling & installed but again the same issue ?
    what could be the reason ?
  • 7.  RE: VisualRF Plan not starting
    Posted Mar 24, 2018 12:21 AM
     Is somebody can help me to open VRF as it was showing error
  • 8.  RE: VisualRF Plan not starting
    Posted Apr 19, 2018 04:37 AM
    I will also tag on to this thread.
    What is the status of the visual RF planner?
    I see that version 8 is not supported on windows 10 from the release notes, and I am struggling to get it working. The symptom mentioned in the thread is the same for me. Try to start the application, get a small visual RF window, and the it diappears like it never existed.
    I have tried emptying folders, uninstalled and whatnot.
    It's a very handy application to have just to place AP's on a PDF for installation.
    It's not scientificly 100% accurate, but many small installs don't want to pay for a proper WiFi survey, and are happy with a predicted model like this.
