VisualRF Plan v7.7 can not import AutoCAD file for floor plan
  • 1.  VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 13, 2014 11:58 AM
    Hey,
    I just downloaded and installed VisualRF Plan v7.7 onto my windows 8.1 64bit OS. But it can not import AutoCAD files (Error message is attached). I tried to run VisualRF Plan in compatibility mode but no help. I am still in the learning process of this software.
    Please advise.
    /S
  • 2.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 13, 2014 05:41 PM
    Hello Shuai Yu.
    I had the same problem few days ago and here is how I fix this issue, I hope it fix yours too..
    Before install 7.7 make sure your computer is running Java 7 Update 45 and Update 45 (64bit)
    Now go to control panel and look for Turn windows features on or off and make sure .Net Framework 3.5 is enable.
    Install Visual RF plan, wait for the installation... If you are ready to upload your CAD file is optional if you remove some of the layers, as we know CAD files are huge.. So you can make it light and remove some extra layers..
    And there you go.. You just upload your CAD file...
    If for some reason you still having the same issue.. Install the application using program compatibility troubleshooter...
    Right click on the application then select troubleshoot compatibility..
    select Test the Program..
    When you finish the installation save the setting..
    Giovanni Saldarriaga
  • 3.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 08:57 AM
    Thanks for the detail steps but did not work for me.
    I installed Java 64bit, make sure .NET3 is enabled and re-installed visualRF plan and ran the troubleshooting and even run the app with administrator right... did not work for me.
    I also tried to hide all but 1 layer in AutoCAD file, still did not work.
    Maybe it is my AutoCAD file issue. Is it possible you can share your dwg file with me to have a try?
  • 4.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 11:14 AM
    That's weir.. Try this CAD... I just uploaded the CAD below  to my RF and works fine..
  • 5.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 11:15 AM
    Sorry, I did not find the uploaded CAD...
  • 6.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 11:36 AM
    sorry... :smileysurprised:
    Im tryng to load the file but is taking for ever.. but here is the web site where you can get somo free CAD files and try..
    www.arcat.com
  • 7.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 11:48 AM
    I tried this
    http://www.arcat.com/details/camploga/03480124.dwg
    Could u try it inside yours to see if you got error? If not, then mine still has installation issue...
  • 8.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 01:48 PM
    The images from that arcat site were able to upload and work in my installation:
    OS: Win7 32bit
    VisualRF Plan version -> from the About link at the top right of the app
    Version: 7.7.rc1 (build: 440)
    Build Date: 2013-11-01 13:57 PDT
    Java Runtime Version: 1.6.0_22
    VisualRF Engine Version: 7.7.0
    VisualRF Engine Build: 75883
    VisualRF Engine Database: 54429
    VisualRF Data Path: C:\Users\rgin\vrfplan
    VisualRF Plan Static: 75883
    All Rights Reserved. Copyright (c) 2002-2013, Aruba Networks, Inc.
  • 9.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 02:27 PM
    Here is the one I have but I am using a windows 8.1 64bit OS.
    So my question: will the v7.7 compatible with windows 8.1 64bit?
  • 10.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 14, 2014 03:01 PM
    We've got it running on several 64-bit installs.  I'll double check with the team to see if they're testing on Win8 or 8.1.
  • 11.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 07:47 AM
    I'm running Win 8.1 64-bit and I dont have any problem.. but.. let's try one more thing my friend..
    Unistall all the RF Software, restart your PC and install RF 7.5 using  Troubleshoot compatibility..
    When you finish the installation if you have this message below please click "NO"  DO NOT run the scripts..and then you will see the CAD file.
    Here is the CAD file you send me.. :smileywink:
  • 12.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 08:15 AM
    Thanks, I definitly can try v7.5 (maybe even 7.6?). However I have hard time locate the download link of older version of VisualRF Plan on support.arubanetworks.com.
    Is it possible you can just provide me with a link?
  • 13.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
  • 14.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 08:42 AM
    This is really interesting...it asks me for login now after I click your link...
    Either I was able to somehow bypass the user check OR aruba recently changed download policy...I was able to download v7.7.
    Anyhow, if it is required to have a valid product serial number in order to download, I might try with the free Dell version.
    Thanks anyway.
  • 15.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 09:01 AM
    Good news for me, might not be to you :)
    I downloaded Dell Version 7.7 b431.
    I installed it via compatible testing and it works on my windows 8.1...
  • 16.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 05:13 PM
    In the case that it's still not working, we've filed defect number DE16933 to look into this further.  We've seen it work and not work on different setups in the lab.
  • 17.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 06:11 PM
    Thanks, do u have a link that I can track the bug?
  • 18.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Jan 15, 2014 08:51 PM
    I'm not aware of any direct customer visibility of defects, but a simple email to support asking status of the defect should get you the answer you're looking for.
  • 19.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Feb 25, 2014 12:26 PM
    All,
    We are experiencing this issue as well (with PDF file for floor plans).
    We have tried various install and uninstalls with different java codes.
    Does anyone from Aruba have any update on this?
    Our reason to pick this version was the availability of AP225's in the device list.
    Is there any other version we could use?
    Thanks for all of your help.
  • 20.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Feb 25, 2014 01:02 PM
    @SoheilSamouhi
    How many floor plans are in the PDF file?  The import only takes the 1st floor plan of a PDF file (current limitation of the import tool used).  Also, is there any crashes in the VisualRF.log file when you attempt import?  I suggest opening as a support case for tracking purposes.
  • 21.  RE: VisualRF Plan v7.7 can not import AutoCAD file for floor plan
    Posted Feb 25, 2014 01:23 PM
    One floor per pdf file
    I fixed it by installing an older version then installing the 7.7-440 on top and it worked fine.  It wouldn't work on a clean install.
