VisualRF won't display - Log4j Error
  • 1.  VisualRF won't display - Log4j Error
    Posted Aug 25, 2017 04:52 AM
    We have an Airwave setup where the VisualRF compnenent has stopped working.  It will either time out on loading, or not let me get to flor level - only to building level.
    Seems the log file is filling up the HDD.  Below is the log after a reboot and clearing space so the web interface actually starts.
    In particular, Log4J seems to be an issue?  What is that used for, and where can I check the settings for how its used?
    Thu Aug 24 23:37:26 2017: Started (PID: 1636)
    Thu Aug 24 23:37:26 2017: Changed roles from old to new roles:
    Thu Aug 24 23:37:26 2017: restarting Airbus Message Server...
    Thu Aug 24 23:37:26 2017: restarting RabbitMQ Message Broker...
    Thu Aug 24 23:37:26 2017: restarting TupleSpaces Server...
    rabbitmq-server not running.
    Starting rabbitmq-server:
    Thu Aug 24 23:37:26 2017: restarting Asynchronous Work Scheduler...
    Warning: PID file not written; -detached was passed.
    Thu Aug 24 23:37:26 2017: restarting In-Memory Store...
    ==== Processed 6984 valid opcodes (in 54586117 bytes) ==========================
    CRC64 checksum is OK
    Thu Aug 24 23:37:28 2017: restarting Rest API Server...
    Stopping redis-server: [FAILED]
    Starting redis-server: Thu Aug 24 23:37:28 2017: restarting Controller XML Query Agent...
    [ OK ]
    Thu Aug 24 23:37:29 2017: restarting AMON message aggregator...
    Thu Aug 24 23:37:29 2017: restarting Aruba Instant Handler...
    Thu Aug 24 23:37:29 2017: restarting Pound Reverse Proxy...
    Thu Aug 24 23:37:29 2017: restarting Performance Monitor...
    Stopping Pound: [FAILED]
    Starting Pound: starting...
    Thu Aug 24 23:37:29 2017: restarting Alert Monitor...
    Thu Aug 24 23:37:30 2017: restarting Device List Cacher...
    Thu Aug 24 2017 23:37:30 GMT-0700 (PDT) 1817 Rest API Server
    Thu Aug 24 2017 23:37:30 GMT-0700 (PDT) 1817 Starting Daemon::RestAPIServer on 6700
    [ OK ]
    Thu Aug 24 23:37:30 2017: restarting HTTP/SNMP Scanner...
    Thu Aug 24 23:37:30 2017: restarting Device Monitor...
    Thu Aug 24 23:37:30 2017: restarting Device Monitor (Poll Now)...
    Thu Aug 24 23:37:31 2017: restarting Client Monitor Worker...
    Thu Aug 24 23:37:31 2017: restarting Configuration Server...
    Thu Aug 24 23:37:31 2017: restarting Configuration Monitor...
    Thu Aug 24 23:37:32 2017: restarting Device Event Collector...
    Thu Aug 24 23:37:32 2017: restarting Device Flash Upgrader...
    Thu Aug 24 23:37:32 2017: restarting Aruba Device HTTPS Handler...
    Thu Aug 24 23:37:32 2017: restarting DNS Fetcher...
    Thu Aug 24 23:37:33 2017: restarting Partial Configuration Update Server...
    Thu Aug 24 23:37:33 2017: restarting PAPI Message Decoder...
    Thu Aug 24 23:37:33 2017: restarting PAPI Facade Queue Message Processor...
    Thu Aug 24 23:37:34 2017: restarting PAPI Message Handler...
    Thu Aug 24 23:37:34 2017: restarting AppRF Client Sessions Processor...
    Thu Aug 24 23:37:34 2017: restarting Scriptorium...
    Thu Aug 24 23:37:35 2017: restarting SNMP Enabler...
    Thu Aug 24 23:37:35 2017: restarting SNMP Fetcher...
    Thu Aug 24 23:37:35 2017: restarting SNMP Trap Handler...
    Thu Aug 24 23:37:35 2017: restarting SNMP V2 Fetcher...
    Thu Aug 24 23:37:36 2017: restarting Synchronous Event Handler...
    Thu Aug 24 23:37:36 2017: restarting Translation Server...
    Thu Aug 24 23:37:36 2017: restarting VisualRF Engine...
    Thu Aug 24 23:37:36 2017: Last PID not available VisualRF Engine...
    Thu Aug 24 23:37:37 2017: Restarting service VisualRF Engine
    Thu Aug 24 23:37:37 2017: restarting WEP Key Setter...
    Thu Aug 24 2017 23:37:37 GMT-0700 (PDT) 1990 Translation Server
    Thu Aug 24 2017 23:37:37 GMT-0700 (PDT) 1990 Starting Daemon::TranslationServer on 3080
    Thu Aug 24 23:37:37 2017: restarting UCC Client Sessions Processor...
    Thu Aug 24 23:37:37 2017: restarting Inline Statistics Processor...
    log4j:WARN No appenders could be found for logger (org.springframework.core.io.support.PathMatchingResourcePatternResolver).
    log4j:WARN Please initialize the log4j system properly.
    log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
    Thu Aug 24 23:37:41 2017: Starting additional Client Monitor Workers
    Thu Aug 24 23:37:42 2017: Starting additional PAPI Decoders
    [Thu Aug 24 23:37:42 2017] http://127.0.0.1:6654/visualrf/startup_status? :: 500 Can't connect to 127.0.0.1:6654 (connect: Connection refused)
    Content: 500 Can't connect to 127.0.0.1:6654 (connect: Connection refused)
    [Thu Aug 24 23:37:43 2017] VisualRF is enabled, but timed out on response (timeout: 10 secs, status: -1)
    Thu Aug 24 23:37:43 2017: VisualRF status: -1
  • 2.  RE: VisualRF won't display - Log4j Error
    Posted Oct 12, 2017 12:27 AM
    Any errors in the /var/log/visualrf.log?
