I continuosly try to change AP properties in VisualRF. Once I change antenna Beamwidth, orientation, and gain. It will default back after first refresh. Can anyone help
We had that problem in a prior version of Airwave and it was resolved in an update.
I don't immediately recall which version it was - I'll go dig through my e-mail history.
What version of Airwave ar you using?
I believe it was in 8.0 and fix in 8.1+ (my problem anyway)
<edit>
Oops, posted to the wrong thread, sorry
</edit>
That was the wrong thread, sorry.
Hi DNBWireless.
What airwave release are you using?
Thank you.
Kartik
