Vitual controler integration with cppm
  • 1.  Vitual controler integration with cppm
    Posted Sep 01, 2017 02:51 AM
    Hi all,
    I have Aruba virtual controler with guests captive portal and need yo integrate that with cppm
    So the captive portal and the authantican for the guest will be in cppm while keeping the old capyive portal look and don't need to rebuild it again
    Can anyone help with steps?
    Thank you all
  • 2.  RE: Vitual controler integration with cppm
    Posted Sep 01, 2017 04:16 AM
    I'd recommend to check out the Aruba Solution Exchange.
    This should help:
    https://ase.arubanetworks.com/solutions/id/37
  • 3.  RE: Vitual controler integration with cppm
    Posted Sep 01, 2017 04:59 AM
    Hi James,
    Thank you for your recommendation,
    I have a nother question
    Can i integrte cppm with arouba virtual controler and make the changes only for guest ssid portal and authanticaion to be on cppm while the corp ssid configuration be on the virtual controler?
    So only i need the cppm for guest and everything else be on the virtual controler
    Or i have to move everything to cppm?
  • 4.  RE: Vitual controler integration with cppm
    Posted Sep 01, 2017 06:11 AM
    You can just move the guest captive portal and auth to CPPM.
  • 5.  RE: Vitual controler integration with cppm
    Posted Sep 04, 2017 06:15 AM
    Videos from this workshop may be helpful to set this up, in addition to Aruba Solution Exchange.
