VLAN 1 Operational State Down - Can't Ping Router
  • 1.  VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 04:57 AM
    Hi
    I have a weird issue with 2 4005 controllers.
    I have assigned VLAN 1 with an IP of 192.168.1.50 on the primary and 192.168.1.51 on the secondary.
    I have added the default gateway (router) to both controllers 192.168.1.1
    On the secondary I can ping the default gateway.
    On the primary I cannot ping it and it will not show on the router in the binding table with the statically assigned IP.
    The VLAN is showing operational state down.  I have tried from the CLI to bring the oper state up by using command interface vlan 1> operstate up but it does not do anything.
  • 2.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 05:12 AM
    Hi
    Is VLAN 1 tagged or untagged to the right port?
    The OAW 4005 is a Aruba7005, which firmware are you running?
     The command operstate up is normally used on VLAN's that don't have physical ports, like a guest VLAN that only has an SSID attached to it.
  • 3.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 05:45 AM
    Yes it is tagged to the correct port.
    It is 6.5.4.7
    Both controllers are running this.
    The second controller has no issue.
    Interface IP Address / IP Netmask Admin Protocol VRRP-IP (VRRP-Id)
    vlan 1 192.168.1.50 / 255.255.255.0 up down none (none)
    VlanId IPAddress Adminstate Operstate PortCount Nat Inside Mode Ports AAA Profile Option-82
    1 192.168.1.50/255.255.255.0 Enabled Down 2 Disabled Regular GE0/0/2 Pc0-7 N/A Disabled
    vlan 1 192.168.1.51 / 255.255.255.0 up up none (none)
    Vlan Status
    1 192.168.1.51/255.255.255.0 Enabled Up 2 Disabled Regular GE0/0/1-0/2 Pc0-7 N/A Disabled
  • 4.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 05:49 AM
    It looks like the port on the first controller is down.
    Can you switch the cables between the controllers to see it the problem moves with it?
    Possible causes:
    - bad cable
    - broken switchport
    - broken port on controller
    Did you set the ports up as a single port? Or Port-Channel?
  • 5.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 05:51 AM
    Yip I switched the cable still only the second controller works so it is not a cable issue
    I have tried a different port on the router and doesn't make a difference.
    I have tried two ports on the controller and it doesn't make a difference.
    I cannot get the operational state to change to up no matter what i do
  • 6.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 06:17 AM
    OK so i changed the port on the controllers and set up a new VLAN - VLAN 100 on both
    The same issue follows.  The first controller stays down and the second comes up.
    I use the command and this time it works and it brings VLAN 100 operational state up but I still cannot ping the default gateway.  I can ping the default gateway from the other controller.  Here is the IP ROUTE from the working controller:
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 192.168.33.1 to network 0.0.0.0 at cost 10
    Gateway of last resort is 192.168.1.1 to network 0.0.0.0 at cost 1
    S* 0.0.0.0/0 [0/1] via 192.168.1.1*
    C 192.168.1.0/24 is directly connected, VLAN100
    And non working:
  • 7.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 06:37 AM
    Hi
    If you issue a write erase all on the first controller and do a complete fresh setup and still it doesn't work then contact TAC, maybe you have a faulty controller.
  • 8.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 06:41 AM
    OK so i have set up another vlan with a local network.
    192.168.33.1 and 192.168.33.2 just plugged into a switch and they can ping each other etc.  I don't think it is a faulty controller
  • 9.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 06:45 AM
    Hi
    Can you sned a picture on how the connections are setup now?
    did you disable Spanning-tree on the controllers? If they are connected by a single connection switch off spanning tree. but please take care not to create loops.
  • 10.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 06:54 AM
    C 192.168.33.0/24 is directly connected, VLAN9
    C 192.168.33.4/32 is an ipsec map default-psk-redundant-master-ipsecmap
    Codes: C - connected, O - OSPF, R - RIP, S - static
    M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
    C 192.168.33.3/32 is an ipsec map default-psk-redundant-master-ipsecmap
  • 11.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 07:25 AM
    OK so now i have just tried using DHCP
    On the secondary controller it gets an IP address
    however the primary just stays blank :/
  • 12.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 07:30 AM
    VLAN issue on the switch?
  • 13.  RE: VLAN 1 Operational State Down - Can't Ping Router
    Posted Aug 07, 2018 07:37 AM
    Could it be an ARP issue?
    The router is not even seeing this device as connected or plugged in ? Yet the second controller is showing
