Wired Intelligent Edge
Vlan 50 with ip address and no untagged ports
  • 1.  Vlan 50 with ip address and no untagged ports
    Posted Oct 12, 2016 04:58 AM
    Hi all,
    I am having this situation and I don´t  know if it have sense.
    In HP 8206zl switch I have one VLAN (between others) like this:
    vlan 50
    ip address 192.168.50.1 255.255.255.0
    untagged ethernet A1
    exit
    *Interface A1 has no ethernet connected. It is empty.
    If I made a "ping" to the ip address 192.168.50.1 from other machine in the network it answers ICMP.
    But...if I quit the port A1 from vlan 50, and I put untagged on VLAN1  the ip 192.168.50.1 does not respond.
    ¿It´s normal? This IP address is gateway for one server in my network and pass through interface A20-A24 (trunk trk1).
    Thanks in advance,
    Txomin
    #ProCurve
    #managementip
    #Untagged
    #VLAN
    #Interface
  • 2.  RE: Vlan 50 with ip address and no untagged ports
    MVP GURU
    Posted Oct 12, 2016 07:42 AM
    Hi, can you clarify "...from other machine in the network" part?
  • 3.  RE: Vlan 50 with ip address and no untagged ports
    Posted Oct 12, 2016 07:56 AM
    Sure!
    A machine located in one switch attached to this one by an LACP trunk.
  • 4.  RE: Vlan 50 with ip address and no untagged ports
    Posted Oct 15, 2016 10:41 AM
    On some switches it's normal for a L3 interface to go down, if there's no single port in the VLAN active.
    otoh, this shouldn't happen when VLAN 50 is active on a trunk to another switch.
