Hi community,
On my company we are deploying a wireless network, working with AP 335, 7210 Controllers, 3810M and 5406 SW and a Virtual Mobility Master.
The controllers are in md mode, managed by the Mobilty Master.
On site A,B,C we have the following scenario:
7210 Controller: LACP port (G0/0/0-1 port members) native vlan 1, allowed vlans: 3387 and any other vlan required.
On the switches side we have an LACP with this config:
untagged vlan 1
tagged vlan 3387, x, x, x
So for example, if we need a new ssid and that ssid is based on vlan 10 then we add that vlan to LACP ports on both sites (controllers and switches)
Everything works well with the config mentioned.
On site Z we have the following scenario:
The site has an existing network all in vlan 1, an SSID assigned to vlan 1.
The controller is in vlan 2 and we also have the vlan 3387.
What we want to do is to replace the existing APs with our 335 APs and broadcast two SSIDs: one based on vlan 1 and another based on vlan 3387.
The problem occurs when we start the controller configuration using the full dialog throug the console. If we put the vlan 2 as native vlan the controller appears on the Mobility Master for a couple of minutes but after that the controller goes down and we cannot reach it anymore (if we issue a ping for example).
So we have left the vlan 1 by default and everything works well. But when we create a Wlan assigned to vlan 1 and the clients connects to it, they receive vlan 2 IPs.
The configuration on the switch is:
LACP port
tagged vlan 1,3387
untagged vlan 2
Controller:
LACP port
tagged vlan 2,3387
untagged vlan 1 (native)
It seems like a wrong configuration but actually it works.
If we config the controller with:
tagged vlan 1,3387
untagged vlan 2 (native) it goes down and then we lose the controller from the mobility master.
So the question is how can we get the controller works with vlan 2 as native and vlan 1,3387 for ssids.
Sorry for the extended message.
Thank you in advance.
#7210
