I have a very odd case going on with my HPE JG963A (1950-48port ,+*2SFP, +2XGT+)
I have exsisting vlans set up one for main infrastructure and one for a phones system both are using the DHCP relays (which i set up 3 years ago) on their set addresses both using a DHCP server on the VLAN1 Network.
VLAN-1 192.168.20.*/22 - Relay server Adress 192.168.21.107
VLAN-10 192.168.19.*/24 - Relay server Adress 192.168.21.107
This all works and VLAN 10 has custom scope options for the phone system ect all being deployed 100% fuctional.
Now I have created another VLAN-666 on scope of 192.168.14.* /24 The DHCP Server has the scope ready set
and the VLAN seems to be functonal in terms of if i set a 192.168.14.*** address on a device staticly i can talk to the 14 range address switches and hardware fine.
However the DHCP function is non exsistant. Ive Even gone as far as Untagged Access port For VLAN 666 and still the relay does not work.
Im pulling my hair out on this one as the other relays on the same switch to the same server are working fine.
Any ideas>?
#Aruba#Port#VLAN
