Vlan for Machine authen
  • 1.  Vlan for Machine authen
    Posted Jun 11, 2013 06:22 AM
    I have question
    How to return Radius Attribute vlan 7,8,9  from IAS  for machine authen connect to Domain
    I  want to machine authen and use ip  from  vlan 789 by random , Because  client estimating 800
    if use subnet   /22 will cause more boardcast  traffice
    Controller without "Enforce Machine authen"
     I set  IAS and controller on figure but can't obtain  ip machine authen policy
  • 2.  RE: Vlan for Machine authen
    Posted Jun 11, 2013 07:58 AM
    You dont have to use any machine authentication to do this.
    You can just make the clients to be distributed among vlan 7, 8 or 9 by using a vlan pool.
    Just go to Configuration > Network > Vlan > Vlan Pool. Here you can add the vlans you want to use:
    Then in your vap profile, just reference the named Vlan Pool:
    This way the clients will be distributed among the vlans in the vlan pool.
  • 3.  RE: Vlan for Machine authen
    Posted Jun 11, 2013 10:42 AM
    Hi Nesvik, thank you for answer
    But i use 802.1x authen ,which i can't use  "Enforce Machine Authen"
     I need  to  Machine Authentication obtain vlan from DHCP server on windows server 2003
    which i do return Attribute vlan
    How to set server rule on server group for matching  and  machine client  obtain among vlan
    I'm try set server rule that
    Reply-MessageequalsmachineStringset vlanClient_HQ
    Which "Client_HQ(hash)"  is vlan pool  ,but machine client can't obtain ip
  • 4.  RE: Vlan for Machine authen
    Posted Jun 11, 2013 11:35 AM
    Applying a VLAN pool through a server derivation rule is not under available to use under the AOS 5.x/6.1.x/6.2.x but it will be available under the 6.3 AOS code .
    You could use Nesvik option in combination with the /22 subnets , if you don't have any applications that require mutlicast to communicate then and you are concern about broadcast you can turn on the following :
    - In the VAP : Drop Broadcast and Multicast (Wireless)
    - On the Wired : BCMC (Broadcast-Multicast) Optimization
  • 5.  RE: Vlan for Machine authen
    Posted Jun 11, 2013 12:11 PM
    Hi vfabian, thank you for answer
    I can  will  download AOS 6.3 from where ?
    i see 6.2 AOS  but i can't  see 6.3 AOS on figure
  • 6.  RE: Vlan for Machine authen
    Posted Jun 11, 2013 01:06 PM
    There's a 6.3 Beta program available, in order to get access you should contact your local SE.
    I wouldn't recommend using AOS 6.3 on your production environment .
  • 7.  RE: Vlan for Machine authen
    Posted Jun 13, 2013 12:21 AM
    Oh
    thank you very much fabian :smileyhappy:
