Wired Intelligent Edge
VLAN Implementation
  • 1.  VLAN Implementation
    Posted Apr 12, 2019 02:17 AM
    Hi there,
    Correct me if I am wrong.
    I would like to implement a VLAN here in my company.
    Currently my network design here is flat network.
    Can we create a multiple VLAN inside a core switch but all connecting switch from the core switch to idf switch is only unmanaged.
    See attached image for my idea.
    Sorry for the design.
  • 2.  RE: VLAN Implementation
    Posted Apr 12, 2019 07:33 AM
    If the access switches are unmanaged it's not possible to implement multiple VLAN's.
    Or you should place every switch in a different VLAN. So every client behind that switch is in the same VLAN
  • 3.  RE: VLAN Implementation
    Posted Apr 14, 2019 08:13 PM
    You mean that, its not possible to connect 2 to 3 hosts with different vlan to  a access switch?
    My problem is every area or quadrant in my company has a different employee that access internet and I want to isolate my workstation and servers from them.
    Maybe I suggets to implement vlan to my access switch.
  • 4.  RE: VLAN Implementation
    Posted Apr 15, 2019 03:31 AM
    You should implement VLAN's at the access switches to achieve this. Without VLAN's at the access switches this is not possible.
