Comware
VLAN interface does not respond ping hp1910
  • 1.  VLAN interface does not respond ping hp1910
    Posted Sep 25, 2015 11:02 AM
    hello, my problem is I can not access the VLAN interfaces.
    The setup is as follows:
    vlan interfaces
    *1   10.1.1.1/24      up manual
    20   10.1.20.1/24   up manual
    Active route table
    Destination IP Address Mask Protocol Preference Next Hop Interface
    0.0.0.0       0.0.0.0 Static         60                           10.0.1.2 Vlan-interface1
    127.0.0.0    255.0.0.0 Direct          0                     127.0.0.1 InLoopBack0
    127.0.0.1    255.255.255.255 Direct   0      127.0.0.1 InLoopBack0
    10.1.20.0    255.255.255.0 Direct   0           10.1.20.1 Vlan-interface20
    10.1.20.1    255.255.255.255 Direct  0      127.0.0.1 InLoopBack0
    10.1.1.0    255.255.255.0 Direct   0             10.1.1.1 Vlan-interface1
    10.1.1.1    255.255.255.255 Direct   0        127.0.0.1 InLoopBack0
    port configuration
    GE1/0/10 20 Hybrid 1
    on port 10 is connected a pc. the gateway to the pc is 10.1.20.1
    this pc can not reach the interface vlna , neither can ping it.
    the settings right? It can be used as the VLAN interface gateway ?
    #hp1910
    #1910
    #VLAN
  • 2.  RE: VLAN interface does not respond ping hp1910
    Posted Sep 25, 2015 01:07 PM
    what's the full config of port 10?
    If the device connected on it has an IP address in the correct range and correct subnet mask then no reason it shouldn't be able to ping the vlan interface unless the port settings are incorrect.
  • 3.  RE: VLAN interface does not respond ping hp1910
    Posted Sep 25, 2015 03:41 PM
    Configures the port 10 as the access VLAN 20
