Hi
i have a Pro Curve 2810-48G swtich and i am trying to separate mobile phone wifi traffic and laptop wifi traffic.
the way i plan to do this is via an access point which supports multiple SSIDs and assign VLans to the SSIDs
i will have
SSID 1 - VLAN1 (Default) - for wireless laptops and desktops
SSID2 - VLAN2 (WIFI) - for wireless mobiles phones / tablets / BYOD
on the switch i have tagged ports 22 and 24 for both V LAN 1 and 2 as these are ports that the Access points will patch into? - is this correct or should the ports only be tagged into VLAN 2
as the access point will have both mobile devices ( VLAN2) and laptops (VLAN1) i have tagged the ports under both VLANS
the next question is do i need to assign an IP address to VLAN 2. the VLAN1 ip address is the current swtich address before VLANS were configured.
and finally how do i go about DHCP for v lan 2?
currently DHCP server has 10.0.0.0/24 scope which is on VLAN1
i would create another scope 10.0.1.0/24 which would be assigned to to any device connecting on VLAN2 but how do i configure this on the switch. i have tried the IP Helper address but i do not think the swtich supports it as its a layer 2 switch?
DHCP is a Windows 2003 server
any help would be greatful..
current running config below..
ProCurve Switch 2810-48G# show run
Running configuration:
; J9022A Configuration Editor; Created on release #N.11.25
hostname "ProCurve Switch 2810-48G"
vlan 1
name "DEFAULT_VLAN"
untagged 1-21,23,25-48
ip address 10.0.0.9 255.255.255.0
tagged 22,24
exit
vlan 2
name "Wifi"
tagged 22,24
exit
#DHCP#VLAN#iphelper#ipaddress
