VLAN is down after Firmware Upgrade
  • 1.  VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 01:52 AM
    Just want to ask the experts because after I upgraded the firmware, seems to be working fine. But after I restarted, i realized that below VLAN are down.
  • 2.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 02:24 AM
    What version did you upgrade to, and what version was running previously? Are you saying your system is working completely inclusive of anything running on VLAN 30, even though you see this anomaly?
    Post the following outputs from the CLI please?
    show vlan status
    show interface port-channel 0
    show interface port-channel 1
    show port status
  • 3.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 04:16 AM
    Thanks for the immediate reply. Actually im new to Aruba networks and just asked also previously from Kdisc98 help for this thing to work. Please refer below screenshot.
  • 4.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 05:32 AM
    Hi Hi,
    I'm here - how may i help.
    Can u please - disable spanning tree on the port of the vlan.
    or contact me via skype and i will try to assist you via remote session.
  • 5.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 10:31 PM
    Hi Kdisc98,
                  I have reset to factory default already and trying to find my way. I will update you once I get lost again. :) Thanks for your very kind support. I do really appreciate it.  :smileyhappy:
  • 6.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 10:52 PM
    Then suddenly got lost. I cannot see that my AP is up.
    Any thoughts? Thanks?
  • 7.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 22, 2013 11:08 PM
    Check the following :
    - Check if your APs are getting an IP address
    - How are your APs reaching the controller : DNS, DHCP Option 43, ADP ?
    - Make sure your APs can reach the controller (console into the AP and see what's going on) and also make sure that there's no firewalls in between blocking GRE or PAPI
    - Make sure that cpsec is not enabled
    - do show log system all see there's any particular errors that might indicate why your APs are failing to attach
    - Is this a master or a local controller ?
    - How's your default AP group configured ?
  • 8.  RE: VLAN is down after Firmware Upgrade
    Posted Jul 23, 2013 02:54 AM
    contact me later on - and i will assist u
