Wired Intelligent Edge
VLAN number re-mapping
  • 1.  VLAN number re-mapping
    Posted Sep 09, 2020 03:25 PM
    I need to present a number of VLANs on a single connection between an Aruba 5406R and an external network. My issue is that several of the VLANs need to re-numbered "in transit".
    This would be relatively trivial on Comware, however I cannot find an equivalent command in ArubaOS-Switch.
    Any ideas?
    Pete
  • 2.  RE: VLAN number re-mapping
    MVP GURU
    Posted Sep 09, 2020 07:56 PM
    I'm afraid that the VLAN Id translation/remapping feature (during transit) was never developed/introduced on ArubaOS-Switch (or older HP ProVision) based switch series...so you're not going to be lucky with an Aruba 5400R zl2 switch series.
    I know for sure it was introduced on ArubaOS-CX based switch series (and not since beginning...but starting from 10.03.0001 IIRC).
  • 3.  RE: VLAN number re-mapping
    MVP GURU
    Posted Sep 10, 2020 02:55 PM
    but not on all ArubaCX product... (only 83xx and after ?)
  • 4.  RE: VLAN number re-mapping
    MVP GURU
    Posted Sep 10, 2020 05:29 PM
    @alagoutte wrote: but not on all ArubaCX product... (only 83xx and after ?)
    Exactly Alexis, you're right!
    The VLAN translation feature was, at least initially (ArubaOS-CX 10.03), introduced only on Aruba 8320, 8325 and 8400X Switch series because those hardware platforms were the only available at time...but with the subsequent release of ArubaOS-CX 10.04 (and newer 10.05) that feature was extended also to Aruba 6300/6400 Switch series (I'm not sure it is really available on the Aruba 6200 too [*]).
    [*] On the ArubaOS-CX 10.05 Command-Line Interface Guide for Aruba 6200 Switch Series there aren't references about vlan translation and show vlan translation commands found instead on CLI Guides related to Aruba 8320, 8325, 8400X and 6300/6400 Switch series.
  • 5.  RE: VLAN number re-mapping
    Posted Sep 11, 2020 04:06 AM
    Today, VLAN translation is available on all AOS-CX switches , except 6200.
  • 6.  RE: VLAN number re-mapping
    MVP GURU
    Posted Sep 11, 2020 04:55 AM
    Thanks Giles for confirming about Aruba 6200!
