vlan port- channel controler
  • 1.  vlan port- channel controler
    Posted Mar 25, 2018 06:34 AM
    hello every one
    i  have a question about the vlan creation and tag on port chanel
    i create a new vlan on conroler and i would like to tag this vlan on on the port chanel who are a trunk with other vlan
    when i creat this vlan i see the port chanel have this configuration is it nornal ?
    i dont found how to remove this configuration ?
    switchport access vlan XX
    i tag the port chanel
    i see the this pofiguration en webui with cli command zone
    switchport trunk allowed vlan 15,23,32,99,134-138,200-206,812,1001,xx
    are there a impact if i push this configuration ?
    not access on controller ?
    beark acces for other vlan ?
    aruba os 6.0
    thx
    best regards
  • 2.  RE: vlan port- channel controler
    Posted Mar 25, 2018 06:47 AM
    Do you want to remove a single vlan from the trunk or do you want to change the trunk into an access port?
  • 3.  RE: vlan port- channel controler
    Posted Mar 25, 2018 07:51 AM
    the actuel configuration is like this
    i woulk tag a new vlan on the PO who are on trunk
    but there are this config too on the PO
    is not good
    acutualy on the po config :
    interface port-chanel 3
    i would like remove this config
    to add a this XX on the trunk allowed on this po
    thx
  • 4.  RE: vlan port- channel controler
    Posted Mar 25, 2018 08:17 AM
    - You should only be configuring the port channel interface
    - The "switchport Mode _________" command determines if it is a trunk or an access port.
    - If the command under the port channel is "switchport mode trunk", the "switchport access vlan" command is ignored.
    To ensure that this is a trunk, do this:
    config t
    interface port channel x
    To add the vlan:
    config t
    switchport trunk allowed vlan add xx
  • 5.  RE: vlan port- channel controler
    Posted Mar 25, 2018 09:14 AM
    ok to resume i add the new on the trunk on port-chanel and the configuration who was on switchport acces vlan xx will be remove
    and i ll have only this configuration on the po
    switchport trunk allowed vlan add xx,15,33,44
    i il do on webui there no impact ?
    i ll be sure
    there this configuration on po :
    inter face port-chanel x
    after my action
    i ll see this configuration on trunk with the new vlan x and i wiil not see "switchpor acces vlan x"
    interface portchanel X
    switchport trunk allowed vlan add xx,15,33,44,xx
    is it correct thre ni impact
    no acces breking
  • 6.  RE: vlan port- channel controler
    Posted Mar 25, 2018 09:16 AM
    can i do this command
    no switchport acces vlan X in the po interface ? in cli
  • 7.  RE: vlan port- channel controler
    Posted Mar 25, 2018 09:56 AM
    Do you want a trunk or an access port?
  • 8.  RE: vlan port- channel controler
    Posted Mar 25, 2018 11:54 AM
    a trunk
    there are acullay a trunk configuration allowed many vlan
    i want add this new lan on the trunk
  • 9.  RE: vlan port- channel controler
    Posted Mar 25, 2018 01:37 PM
    The instructions in my post before should work.
  • 10.  RE: vlan port- channel controler
    Posted Mar 25, 2018 02:11 PM
    ok thx
    and after  add the new vlan on the truck on the PC ? to be clear on the the PC ?
  • 11.  RE: vlan port- channel controler
    Posted Mar 25, 2018 02:38 PM
    Thr "switch port access" command is ignored if you have "switchport mode trunk". You do not have to remove it.
  • 12.  RE: vlan port- channel controler
    Posted Mar 25, 2018 02:46 PM
    ok thank you for your information and your answer
