Wired Intelligent Edge
VLAN tagging and trunk on a VSF setup
  • 1.  VLAN tagging and trunk on a VSF setup
    Posted Nov 19, 2019 10:18 AM
    Hi, I have 2 Aruba 2930F switches, configured as VSF (Switch 1 Commander, Switch 2 Standby) using 1 vsf link with 2 ports.
    I've setup two trunk groups like this:
    trunk 1/22,2/22 trk1 lacp
    trunk 1/21,2/21 trk2 lacp
    Then I configured vlan tagging on certain ports, in the same way on both switches. And finally I setup the vlans that coul be passed through trunks:
    interface trk1 tagged vlan 10,20,30,40
    However, I can't get my vlan up. I don't have connection of my vlan ports through my trunk groups.
    Could someone tell me what I'm doing wrong?
    My running configuration:
    Running configuration:
    ; hpStack_WC Configuration Editor; Created on release #WC.16.05.0007
    ; Ver #12:08.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ba
    hostname "Enlaces-Commander"
    vsf
    enable domain 9001
    member 1
    type "JL259A" mac-address 08f1ea-4a4020
    priority 255
    link 1 1/23-1/24
    link 1 name "I-Link1_1"
    link 2 name "I-Link1_2"
    exit
    member 2
    type "JL259A" mac-address 548028-6068e0
    priority 128
    link 1 2/23-2/24
    link 1 name "I-Link2_1"
    link 2 name "I-Link2_2"
    exit
    port-speed 1g
    exit
    time timezone -3
    snmp-server community "public" unrestricted
    snmp-server contact "Matias Vilar"
    vlan 1
    name "DEFAULT_VLAN"
    untagged 1/1-1/20,1/25-1/28,2/1-2/20,2/25-2/28,Trk1-Trk2
    ip address 10.250.250.18 255.255.255.0
    exit
    vlan 10
    name "VL 10"
    tagged 1/1,2/1
    no ip address
    exit
    vlan 20
    name "VL 20"
    tagged 1/2,2/2
    no ip address
    exit
    vlan 30
    name "VL 30"
    tagged 1/3,2/3
    no ip address
    exit
    vlan 40
    name "VL 40"
    tagged 1/4,2/4
    no ip address
    exit
    vlan 50
    name "VL 50"
    tagged 1/5,2/5
    no ip address
    exit
    vlan 60
    name "VL 60"
    tagged 1/6,2/6
    no ip address
    exit
    vlan 70
    name "VL 70"
    tagged 1/7,2/7
    no ip address
    exit
    vlan 80
    name "VL 80"
    tagged 1/8,2/8
    no ip address
    exit
    vlan 90
    name "VL 90"
    tagged 1/9,2/9
    no ip address
    exit
    vlan 100
    name "VL 100"
    tagged 1/10,2/10
    no ip address
    exit
    vlan 110
    name "VL 110"
    tagged 1/11,2/11
    no ip address
    exit
    vlan 120
    name "VL 120"
    tagged 1/12,2/12
    no ip address
    exit
    vlan 130
    name "VL 130"
    tagged 1/13,2/13
    no ip address
    exit
    vlan 140
    name "VL 140"
    tagged 1/14,2/14
    no ip address
    exit
    vlan 150
    name "VL 150"
    tagged 1/15,2/15
    no ip address
    exit
    vlan 160
    name "VL 160"
    tagged 1/16,2/16
    no ip address
    exit
    vlan 170
    name "VL 170"
    tagged 1/17,2/17
    no ip address
    exit
    vlan 180
    name "VL 180"
    tagged 1/18,2/18
    no ip address
    exit
    vlan 190
    name "VL 190"
    tagged 1/19,2/19
    no ip address
    exit
    vlan 200
    name "VL 200"
    tagged 1/20,2/20
    no ip address
    exit
    spanning-tree Trk1 priority 4
    spanning-tree Trk2 priority 4
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    Cordial greetings
    Gabriel
  • 2.  RE: VLAN tagging and trunk on a VSF setup
    MVP GURU
    Posted Nov 19, 2019 11:19 AM
    Hello Gabriel,
    are you so kind to post the output of commands listed below?
    VLAN status for aggregated interface trk1 (made of 1/22+2/22):
    show vlan port trk1 detail
    VLAN status for aggregated interface trk2 (made of 1/21+2/21):
    show vlan port trk2 detail
    As far as I can understand from your Aruba 2930F VSF configuration both aggregated interfaces (trk1 and trk2) were ONLY set to be untagged members of VLAN id 1 (default)...there isn't any reference to other VLAN ids thus your statement:
    @neok wrote: And finally I setup the vlans that coul be passed through trunks:
    seems wrong...there is no tagging on trk1 (and both checks above shall confirm). Redo commands:
    interface ethernet trk1 tagged vlan 10,20,30,40
    interface ethernet trk2 tagged vlan 10,20,30,40
    and then re-check VLAN status for both aggregated trunks (trk1 and trk2)...you should discover that trk1 and trk2 are now tagged members of VLAN ids 10, 20, 30 and 40 (other than being untagged members of VLAN id 1).
    I don't understand WHY you tag single interfaces in this way:
    1/1-1/20 untagged on VLAN 1
    2/1-2/20 untagged on VLAN 1
    and, concurrently:
    1/1 and 2/1 tagged only on VLAN 10
    1/2 and 2/2 tagged only on VLAN 20
    1/3 and 2/3 tagged only on VLAN 30
    1/4 and 2/4 tagged only on VLAN 40
    1/5 and 2/5 tagged only on VLAN 50
    1/6 and 2/6 tagged only on VLAN 60
    1/7 and 2/7 tagged only on VLAN 70
    1/8 and 2/8 tagged only on VLAN 80
    1/9 and 2/9 tagged only on VLAN 90
    1/10 and 2/10 tagged only on VLAN 100
    1/11 and 2/11 tagged only on VLAN 110
    1/12 and 2/12 tagged only on VLAN 120
    1/13 and 2/13 tagged only on VLAN 130
    1/14 and 2/14 tagged only on VLAN 140
    1/15 and 2/15 tagged only on VLAN 150
    1/16 and 2/16 tagged only on VLAN 160
    1/17 and 2/17 tagged only on VLAN 170
    1/18 and 2/18 tagged only on VLAN 180
    1/19 and 2/19 tagged only on VLAN 190
    1/20 and 2/20 tagged only on VLAN 200
    what's the final purpose? why this pattern? who is connected to each pair (e.g. on 1/1 and 1/2)?
  • 3.  RE: VLAN tagging and trunk on a VSF setup
    Posted Nov 21, 2019 07:45 AM
    Sorry @parnassus, I paste a wrong running configuration, my mistake.
    This is the correct show running-config output:
    vsf
    enable domain 9001
    member 1
    priority 255
    link 1 1/23-1/24
    exit
    member 2
    priority 128
    link 1 2/23-2/24
    exit
    port-speed 1g
    exit
    time timezone -3
    snmp-server contact "neok"
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1/1-1/20,2/1-2/20
    untagged 1/25-1/28,2/25-2/28,Trk1-Trk2
    exit
    vlan 10
    name "VL 10"
    untagged 1/1,2/1
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 20
    name "VL 20"
    untagged 1/2,2/2
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 30
    name "VL 30"
    untagged 1/3,2/3
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 40
    name "VL 40"
    untagged 1/4,2/4
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 50
    name "VL 50"
    untagged 1/5,2/5
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 60
    name "VL 60"
    untagged 1/6,2/6
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 70
    name "VL 70"
    untagged 1/7,2/7
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 80
    name "VL 80"
    untagged 1/8,2/8
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 90
    name "VL 90"
    untagged 1/9,2/9
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 100
    name "VL 100"
    untagged 1/10,2/10
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 110
    name "VL 110"
    untagged 1/11,2/11
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 120
    name "VL 120"
    untagged 1/12,2/12
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 130
    name "VL 130"
    untagged 1/13,2/13
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 140
    name "VL 140"
    untagged 1/14,2/14
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 150
    name "VL 150"
    untagged 1/15,2/15
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 160
    name "VL 160"
    untagged 1/16,2/16
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 170
    name "VL 170"
    untagged 1/17,2/17
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 180
    name "VL 180"
    untagged 1/18,2/18
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 190
    name "VL 190"
    untagged 1/19,2/19
    tagged Trk1-Trk2
    no ip address
    exit
    vlan 200
    name "VL 200"
    untagged 1/20,2/20
    tagged Trk1-Trk2
    no ip address
    exit
    no tftp server
    no autorun
    I think that my setup not working because I missing 'ethernet' command:
    interface trk2 tagged vlan 10,20,30,40
    Now I execute:
    and works like a charm.
    The show running-config I send include the last correct command.
    My final purpose is that all vlans flow through trk1 and trk2 to a two servers configured in Nic Teaming. In this servers I run virtual firewall appliances.
    If you see anything that can be improved in this configuration, please let me know.
    Thank you very much for your help.
    Best regards
    Gabriel
