Developer
VLAN tagging between AOS and AOS-CX
This thread has been viewed 29 times
  • 1.  VLAN tagging between AOS and AOS-CX
    Posted Nov 14, 2022 12:35 PM
    I hope someone can help me.
    I have the following problem:
    Aruba 2540-48G-PoE+ 4SFP+ Switch and I wants to connect it with a Aruba CX 6000 12G PoE+ Switch.
    It works fine as long as there is no vlan tagging, which is needed.
    How can I connect multiple VLANs between AOS und AOS-CX?
    On 2540 I configure VLAN 1,48,50 as tagged.
    On CX6000 I configure VLAN trunk allow 1,48,50 with VLAN 1 as native vlan.
    But there is no communication between the switches.
    If someone says, It doesn't work, it is his limit not yours.
  • 2.  RE: VLAN tagging between AOS and AOS-CX
    MVP EXPERT
    Posted Nov 14, 2022 02:27 PM
    Hi Haensen87,
    On the 2540 you tagged vlan 1 where this the pvid vlan (what is untagged) on the CX6000.
    Did you enable the interface on the CX6000? Is the interface up?
    Example:
    interface 1/1/1
    no shutdown
    no routing
    description "link_to_link"
    vlan trunk native 1
    vlan trunk allowed 1,48,50
    exit​
    Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: VLAN tagging between AOS and AOS-CX
    MVP GURU
    Posted Nov 15, 2022 05:15 AM
    What do you have on 2540 when use command :
    show port X detail
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 4.  RE: VLAN tagging between AOS and AOS-CX
    Posted Nov 16, 2022 02:23 AM
    the command is
    show interface <number>
    and i get information for name, link status, mac address, total send/received packages and errors
    @mkk: yes the port on cx6000 is enabled like every port in default configuration in lower cx series
    I already enter the commands you send.
    On Aruba 2540 you can't find information for pvid, I guess it is the default VLAN, which is by default VLAN 1.
    When I configure the connection with just "vlan access 1" everything works fine, but I need additional vlans on the CX Switch.
    I can try next week some things when I'm back at customers site.
  • 5.  RE: VLAN tagging between AOS and AOS-CX
    Posted Nov 16, 2022 12:47 PM
    Perhaps adding the value `tag` after defining the native vlan? Like so:
    interface 1/1/1
        no shutdown
        no routing
        vlan trunk native 1 tag
        exit
  • 6.  RE: VLAN tagging between AOS and AOS-CX
    Posted Nov 22, 2022 08:16 AM
    Thanks to Tiffany.Chiapuzio-Wong the value "tag" helped.
    Now everything works as I wished.
