VLAN1 should not be used for Master-Master VRRP??
  • 1.  VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 11:13 AM
    I am testing Master-Master, Master-Standby VRRP shown below:
    [Master-Master]  ArubaOS 5.0.4.6  Aruba 3400
    interface vlan 1
            ip address 172.200.1.206 255.255.252.0
    master-redundancy
      master-vrrp 10
      peer-ip-address 172.200.1.207 ipsec ********
    vrrp 10
      priority 110
      ip address 172.200.1.208
      vlan 1
      preempt
      tracking master-up-time 30 add 20
      no shutdown
    ip default-gateway 172.200.1.1
    [Master-Standby]  ArubaOS 5.0.4.6  Aruba 3400
    interface vlan 1
            ip address 172.200.1.207 255.255.252.0
    master-redundancy
      master-vrrp 10
      peer-ip-address 172.200.1.206 ipsec ********
    vrrp 10
      priority 110
      vlan 1
      preempt
      no shutdown
    When I configured above, WebUI for 172.200.1.208 has a problem. After typed userid and password in WebUI,
    it takes so long (more than 30mins) to show first screen. In the show log,
    May  3 03:37:50  webui[1314]: PAPI_Send: To: 7f000001:8224 Type:0x4 Timed out.
    Also, when I tried to perform "show running-config" in Master-Master controller using serial connection,
    Module STM busy is displayed.
    (Master-Master) #show run
    Building Configuration...
    Module STM is busy. Please try later
    There is a entry in show log:
    May  3 03:24:46  stm[1432]: <304001> <ERRS> |stm|  Unexpected stm (Station managment) runtime error at data_path_handler, 649, data_path_handler: recv - Network is down
    Off cource, Master-Master and Master-Standby communicates each other in Layer2 switch.
    I left above over night and WebUI showed normally and show running-config responded normally. I do not know how long did it take for timeout.
    From my experience in past, when I used VLAN1 for Master-Local redundancy, same symptom occured.
    Since then, I avoid using VLAN1 for Master-Master or Master-Local controller ipsec communication.
    If I use VLAN10 instead of VLAN1, everything works fine. (I posted Master-Master and Master-Standby VRRP redundancy successful case using VLAN10 in previous post)
    I am going to attach show log below. It seems that PAPI communication fails, even though two controllers are connected each other through VLAN1.
    Aruba's sample configuration never use VLAN1 for actual controller-controller communication. Aruba sample config uses VLAN99, not VLAN1. Also Loopback should be defined as a endpoint of controller cimmunication.
    I am fine how to fix this problem, just avoid using VLAN1. But I want to see Aruba's document why VLAN1 should not be used.
    [Master-Master's show log all - from initial boot time]
    May  3 03:23:49  ike[1338]: <103062> <INFO> |ike|  Starting cryptoPOST
    May  3 03:23:51  fpapps[1406]: <315382> <CRIT> |fpapps|  Reboot Cause: User reboot.
    May  3 03:23:52  isakmpd[1422]: <103061> <ERRS> |ike|  udp_make: setsockopt (-1, 65535, 4, 0x7f8aab40, 4)
    May  3 03:23:52  isakmpd[1422]: <103061> <ERRS> |ike|  virtual_bind_ADDR_ANY: could not allocate default IPv6 ISAKMP port(s)
    May  3 03:23:55  KERNEL:     max_val[0] = a2c2a, max_val[others] = 3640e,
    /////// Omit several KERNEL lines ///////
    May  3 03:23:55  KERNEL: Aruba Networks
    May  3 03:23:55  KERNEL: ArubaOS Version 5.0.4.6 (build 33270 / label #33270)
    May  3 03:23:55  KERNEL: Built by p4build@corsica on 2012-04-13 at 07:05:48 PDT (gcc version 3.4.3)
    May  3 03:23:55  KERNEL: ility-core init in kernel
    May  3 03:23:55  KERNEL: klogd started: BusyBox v1.01 (2012.04.13-14:01+0000)
    May  3 03:24:04  nanny[1262]: PAPI_Send: To: 7f000001:8407 Type:0x4 Timed out.
    May  3 03:24:06  cts[1463]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 03:24:09  mobileip[1436]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 03:24:10  nanny[1262]: PAPI_Send: To: 7f000001:8407 Type:0x4 Timed out.
    May  3 03:24:12  dbsync[1445]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 03:24:12  snmp[1439]: PAPI_Send: To: 7f000001:8212 Type:0x4 Timed out.
    May  3 03:24:12  snmp[1441]: PAPI_Send: To: 7f000001:8212 Type:0x4 Timed out.
    May  3 03:24:13  authmgr[1431]: PAPI RxPacket: ACK to invalid packet type 0x00000022
    May  3 03:24:13  syslogdwrap[1401]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 03:24:16  nanny[1262]: PAPI_Send: To: 7f000001:8407 Type:0x4 Timed out.
    May  3 03:24:18  cli[1321]: PAPI_Send: To: 7f000001:8372 Type:0x4 Timed out.
    May  3 03:24:18  fpapps[1406]: <313256> <WARN> |fpapps| Route resolve returned an Error
    May  3 03:24:18  fpapps[1505]: <313328> <WARN> |fpapps|  vrrp: vrid "10" - VRRP state transitioned from INIT to BACKUP
    May  3 03:24:18  httpd[1466]: PAPI_Send: To: 7f000001:8214 Type:0x4 Timed out.
    May  3 03:24:20  publisher[1399]: <306510> <WARN> |publisher|  Dropping message from 8214 for service 'aaa-idle-user-timeout (service not found)'
    May  3 03:24:22  KERNEL: 3:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    May  3 03:24:25  KERNEL: 1:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    May  3 03:24:25  snmp[1441]: IP addr 0xa8001ce port 0
    May  3 03:24:25  snmp[1441]: trapSrcIp 0x0
    May  3 03:24:28  ads[1449]: PAPI_Send: To: 7f000001:8214 Type:0x4 Timed out.
    May  3 03:24:34  authmgr[1431]: <325022> <ERRS> |authmgr|  Bogus VLAN ID:4095 received.
    May  3 03:24:48  fpapps[1505]: <313328> <WARN> |fpapps|  vrrp: vrid "10" - VRRP state transitioned from BACKUP to MASTER
    May  3 03:24:48  fpapps[1505]: <313331> <WARN> |fpapps|  VRRP: vrid "10" - Missed 3 Hello Advertisements from VRRP Master 172.200.1.206
    May  3 03:25:22  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:25:58  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8224 failed, errno Connection timed out
    May  3 03:26:50  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8224 failed, errno Connection timed out
    May  3 03:26:54  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8345 failed, errno Connection timed out
    May  3 03:26:54  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:28:14  cli[1321]: USER: admin has logged in using serial.
    May  3 03:28:26  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:28:49  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:28:49  webui[1314]: USER: Error Executing the Command
    May  3 03:28:53  cli[1321]: PAPI_Send: To: 7f000001:8222 Type:0x4 Timed out.
    May  3 03:28:53  cli[1321]: USER:admin Error Executing the Command
    May  3 03:29:49  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:29:49  webui[1314]: USER: Error Executing the Command
    May  3 03:29:58  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:30:49  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:30:49  webui[1314]: USER: Error Executing the Command
    May  3 03:31:30  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:31:49  webui[1314]: PAPI_Send: To: 7f000001:8224 Type:0x4 Timed out.
    May  3 03:32:49  webui[1314]: PAPI_Send: To: 7f000001:8222 Type:0x4 Timed out.
    May  3 03:32:49  webui[1314]: USER: Error Executing the Command
    May  3 03:33:02  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:33:49  webui[1314]: PAPI_Send: To: 7f000001:8224 Type:0x4 Timed out.
    May  3 03:34:34  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:34:50  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:34:50  webui[1314]: USER: Error Executing the Command
    May  3 03:35:50  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:36:06  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:36:50  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:36:50  webui[1314]: USER: Error Executing the Command
    May  3 03:37:38  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:38:50  webui[1314]: PAPI_Send: To: 7f000001:8222 Type:0x4 Timed out.
    May  3 03:38:50  webui[1314]: USER: Error Executing the Command
    May  3 03:39:10  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:39:48  cli[1321]: PAPI_Send: To: 7f000001:8222 Type:0x4 Timed out.
    May  3 03:39:48  cli[1321]: USER:admin Error Executing the Command
    May  3 03:39:50  webui[1314]: PAPI_Send: To: 7f000001:8224 Type:0x4 Timed out.
    May  3 03:39:50  webui[1314]: USER: Error Executing the Command
    May  3 03:40:42  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:42:14  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:43:12  webui[1314]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 03:43:12  webui[1314]: USER: Error Executing the Command
    In the log,
    is really strange. Because Master-Master's VLAN1 interface IP is 172.200.1.206. Therefore this Master-Master(perhaps VRRP IP 172.200.1.208) tried to receive VRRP Hello from himself, 172.200.1.206 .... I do not know why this only happens with VLAN1.
    #3400
  • 2.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 11:16 AM
    Turn authentication on, on the VRRP on both sides to make sure if you have a mystery VRRP or HSRP on your network, it is not bothering it.
  • 3.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 12:04 PM
    I added authentication for each VRRP 10 definition:
       Auth type PASSWORD, Auth data: ********
    then rebooted Master-Master and Master-Standby.
    Symptom was slightly changed.
    WebUI through VRRP IP 172.200.1.208 - Became OK. (Previously NG)
    WebUI to 172.200.1.206 (Master-Master) - Became OK. (Previously NG)
    WebUI to 172.200.1.207 (Master-Standby) - Became NH (Previously OK)
    show run at Master-Master became OK (Previously NG - Module STM is busy)
    show run at Master-Standby became NG (Previously OK)
    I still believe that VLAN1 is special and should not be used for Controller communication.
    If I keep VLAN1 having initial IP 172.21.x.x. assigned and disabled,
    and assign VLAN10 for controller-controller communication, everything worked fine.
    Do you know why VLAN1 is so special?
  • 4.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 01:10 PM
    I use VLAN 1 for VRRP in my production master-standy and my lab master-standy setup and never saw a problem.
  • 5.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 01:14 PM
    There's nothing wrong with VLAN 1 conceptually in this scenario. A lot of security purists don't like the use of VLAN 1 on any network gear, but that's subjective.
    Anyway, can you post your physical interface config, "show port status" outputs, "show arp" outputs, "show vlan" outputs please?
    I've used VLAN 1 tons for VRRP. I've hit some bugs with it in advanced setups that the support guys resolved with updates. Need to see your outputs first to work out what's going on.
    Thanks.
  • 6.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 01:22 PM
    You're right about the purists, Racking Monkey.  I think it all goes back to Cisco always telling people to avoid using VLAN 1 on their switches, because Cisco  uses VLAN 1 for control plane traffic on their switches.  I have no idea if Aruba does that though.
  • 7.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 01:29 PM
    Bl**dy Cisco. LOL. Yeah, that's where it comes from. Even then though, it's nothing that worries me once you understand why they tow that line. Anyway....
    AFAIK, Aruba is VLAN agnostic as it were in terms of specific numbers (quite right too). Can't remember any specific gotchas.
    There's two typical stumbling blocks I've seen people hit.
    1. Leaving the ports untrusted where the VRRP hellos come in/out. That will break it unless you put an ACL on the port (I had to write one once).
    2. Overlapping VRRP IDs or IP conflicts. That tends to wreck it really quickly.
  • 8.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 03:10 PM
    Hi The.racking.monkey and mike.j.gallagher,
    I am going to attach outputs here.
    I think this issue is "Master-Master redundancy" issue. In the beninning, I configured VRRP10 in VLAN1 and that was fine.
    Afterwords, when I configured Master-Master redundancy over VRRP10, this symptom started.
    Switch is Cisco 2960G and all port is default (VLAN1)
    Module STM is busy. Please try later ===> This is the symtom (1)
    Another symptom is - 172.200.1.206 and 172.200.1.208 WebUI does not respond - process is very slow.
                                            172.200.1.207 WebUI is fine.
    (Master-Master) #show port status
    Port Status
    Slot-Port  PortType  adminstate  operstate  poe      Trusted  SpanningTree  PortMode
    1/0        GE        Enabled     Up         Enabled  Yes      Forwarding    Access
    1/1        GE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/2        GE        Enabled     Down       Enabled  Yes      Disabled      Access
    1/3        GE        Enabled     Down       Enabled  Yes      Disabled      Access
    (Master-Master) #show arp
    Protocol        Address         Hardware Address        Interface
    Internet        172.200.1.33     68:B5:99:F4:15:5D       vlan1
    Internet        172.200.1.207    00:0B:86:6D:A5:EC       vlan1
    (Master-Master) #show vlan
    VLAN CONFIGURATION
    VLAN  Description  Ports
    1     Default      GE1/0-3 Pc0-7
    (Master-Master) #show crypto ipsec sa
    IPSEC SA Active Session Information
    Initiator IP     Responder IP      InitiatorID   ResponderID  Flags    Start Time      Inner IP
    172.200.1.206     172.200.1.207       172.200.1.206/32 172.200.1.207/32  T    May  3 08:00:33     -
    172.200.1.207     172.200.1.206       172.200.1.207/32 172.200.1.206/32  T    May  3 08:00:26     -
    Flags: T = Tunnel Mode; E = Transport Mode; U = UDP Encap
           L = L2TP Tunnel; N = Nortel Client; C = Client
    Total IPSEC SAs: 2
    <<Comment - I think two ipsec tunnels between Master-Master and Master-Standby is not normal .. I think there should be only one ipsec sa>>
    (Master-Master) #show vrrp
    Virtual Router 10:
        Description
        Admin State UP, VR State MASTER
        IP Address 172.200.1.208, MAC Address 00:00:5e:00:01:0a, vlan 1
        Priority 110, Advertisement 1 sec, Preemption Enable
        Auth type NONE
        tracking type is master-up-time, duration 30 minutes, value 20
        tracked priority 130
    (Master-Master) show log all
    I think - key to resolve this problem is the log message:
    May  3 08:00:05  fpapps[1505]: <313331> <WARN> |fpapps|  VRRP: vrid "10" - Missed 3 Hello Advertisements from VRRP Master 172.200.1.206
    This is Master-Master, and Master-Master's VLAN1 interface is 172.200.1.206. Log above tried to receive Hello Advertisements from 172.200.1.206 - that is itself. At this time, Master-Master has VRRP IP Address 172.200.1.208. If Master-Master sends Hello Advertisement using IP 172.200.1.208 (VRRP IP) but expecting to receive Hello Advertisement from 172.200.1.206, this never happen.....
    May  3 07:59:12  KERNEL: klogd started: BusyBox v1.01 (2012.04.13-14:01+0000)
    May  3 07:59:21  nanny[1262]: PAPI_Send: To: 7f000001:8407 Type:0x4 Timed out.
    May  3 07:59:22  syslogdwrap[1401]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 07:59:23  cts[1462]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 07:59:27  mobileip[1436]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 07:59:27  nanny[1262]: PAPI_Send: To: 7f000001:8407 Type:0x4 Timed out.
    May  3 07:59:29  dbsync[1444]: PAPI_Send: To: 7f000001:8226 Type:0x4 Timed out.
    May  3 07:59:29  snmp[1441]: PAPI_Send: To: 7f000001:8212 Type:0x4 Timed out.
    May  3 07:59:30  authmgr[1431]: PAPI RxPacket: ACK to invalid packet type 0x00000022
    May  3 07:59:30  snmp[1440]: PAPI_Send: To: 7f000001:8212 Type:0x4 Timed out.
    May  3 07:59:33  nanny[1262]: PAPI_Send: To: 7f000001:8407 Type:0x4 Timed out.
    May  3 07:59:34  httpd[1466]: PAPI_Send: To: 7f000001:8214 Type:0x4 Timed out.
    May  3 07:59:35  fpapps[1406]: <313256> <WARN> |fpapps| Route resolve returned an Error
    May  3 07:59:35  fpapps[1505]: <313328> <WARN> |fpapps|  vrrp: vrid "10" - VRRP state transitioned from INIT to BACKUP
    May  3 07:59:37  cli[1321]: PAPI_Send: To: 7f000001:8372 Type:0x4 Timed out.
    May  3 07:59:37  publisher[1399]: <306510> <WARN> |publisher|  Dropping message from 8214 for service 'aaa-idle-user-timeout (service not found)'
    May  3 07:59:40  KERNEL: 0:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    May  3 07:59:44  KERNEL: 3:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    May  3 07:59:44  snmp[1441]: IP addr 0xa8001ce port 0
    May  3 07:59:44  snmp[1441]: trapSrcIp 0x0
    May  3 07:59:45  ads[1450]: PAPI_Send: To: 7f000001:8214 Type:0x4 Timed out.
    May  3 07:59:46  cli[1321]: PAPI_Send: To: 7f000001:8372 Type:0x4 Timed out.
    May  3 07:59:50  authmgr[1431]: <325022> <ERRS> |authmgr|  Bogus VLAN ID:4095 received.
    May  3 08:00:03  stm[1432]: <304001> <ERRS> |stm|  Unexpected stm (Station managment) runtime error at data_path_handler, 649, data_path_handler: recv - Network is down
    May  3 08:00:05  fpapps[1406]: PAPI RxPacket: Timer already removed - could be a duplicate ACK
    May  3 08:00:05  fpapps[1505]: <313328> <WARN> |fpapps|  vrrp: vrid "10" - VRRP state transitioned from BACKUP to MASTER
    May  3 08:00:39  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:01:15  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8224 failed, errno Connection timed out
    May  3 08:01:15  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8345 failed, errno Connection timed out
    May  3 08:02:07  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8224 failed, errno Connection timed out
    May  3 08:02:10  publisher[1399]: <306514> <ERRS> |publisher|  Pubsub send message code 0 source port 8378 to destination port 8345 failed, errno Connection timed out
    May  3 08:02:11  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:46:39  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    /// Omitted same wms messages ///
    May  3 08:48:11  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:49:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:49:41  webui[1312]: USER: Error Executing the Command
    May  3 08:49:43  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:50:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:50:41  webui[1312]: USER: Error Executing the Command
    May  3 08:51:15  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:51:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:52:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:52:41  webui[1312]: USER: Error Executing the Command
    May  3 08:52:47  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:53:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:53:43  cli[1321]: USER: admin has logged in using serial.
    May  3 08:54:19  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:54:23  cli[1321]: PAPI_Send: To: 7f000001:8222 Type:0x4 Timed out.
    May  3 08:54:23  cli[1321]: USER:admin Error Executing the Command
    May  3 08:54:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:54:41  webui[1312]: USER: Error Executing the Command
    May  3 08:55:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:55:41  webui[1312]: USER: Error Executing the Command
    May  3 08:55:51  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:56:41  webui[1312]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    May  3 08:57:23  wms[1427]: PAPI_Send: To: 7f000001:8345 Type:0x4 Timed out.
    (Master-Standby) #show port status
    Port Status
    1/0        GE        Enabled     Up         Enabled  Yes      Disabled      Access
    (Master-Standby) #show arp
    Internet        172.200.1.206    00:0B:86:6D:A6:98       vlan1
    (Master-Standby) #show vlan
    VLAN CONFIGURATION
    (Master-Standby) #show vrrp
    Virtual Router 10:
        Description
        Admin State UP, VR State BACKUP
        Priority 100, Advertisement 1 sec, Preemption Enable
        Auth type NONE
        tracked priority 100
    (Master-Standby) #show crypto ipsec sa
    172.200.1.206     172.200.1.207       172.200.1.206/32 172.200.1.207/32  T    May  3 10:41:33     -
    172.200.1.207     172.200.1.206       172.200.1.207/32 172.200.1.206/32  T    May  3 10:41:26     -
    Total IPSEC SAs: 2
    For comparison, I will change VLAN from VLAN1 to VLAN10 and post the same command outputs.
  • 9.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 04:49 PM
    Please post your physical interface commands/running config too.
  • 10.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 04:50 PM
    Full config for both boxes excluding ACLs/roles etc. Starting at first physical port etc.
  • 11.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 03, 2012 08:15 PM
    I have been trying to isolate this symptom and found some facts.
    First of all, this issue is not related to VLAN1. I could reproduce the same symptom with VLAN10.
    1. Symptom
    In Master-Master and Master-Standby VRRP redundancy environment, such as
    Master-Master VLAN1 172.200.1.206     VRRP priority 110
    Master-Standby VLAN1 172.200.1.207   VRRP priority 100
    If I powered off then power on Master-Master and Master-Standby at the same time,
    symptom (1) With serial console, show running-config command times out with
    Symptom (2) WebUI did not show all screen. In the left borrom corner, "READ xxxxx" is displayed.
    2. Problem isolation
    When these symptom is occuring, there are two ipsec sas established between Master-Master and Master-Local.
    (Master-Master) # show crypto ipsec sa
    Initiator IP     Responder IP      InitiatorID   ResponderID  Flags    Start Ti e      Inner IP
    172.200.1.206     172.200.1.207       172.200.1.206/32 172.200.1.207/32  T    May    05:55:42     -
    172.200.1.207     172.200.1.206       172.200.1.207/32 172.200.1.206/32  T    May    05:55:46     -
    Total IPSEC SAs: 2
    When this symprom is occuring, reboot the controller which cannot execute show run or WebUI.
    (Only one controller at time)
    After controller becomes up, there is only one sa exist. I believe that this is normal indication.
    Also show running-config and WebUI works fine on both controllers.
    172.200.1.207     172.200.1.206       172.200.1.207/32 172.200.1.206/32  T    May    13:49:04     -
    Total IPSEC SAs: 1
    3. Assumption
    I assume that the reason why this symptom occurs is - when Master-Master or Master-Standby controller power on at the same time, both controller tries to establish ipsec session. If two ipsec sessions are established in error, this symptom might occur.
    Also, if we newly configure Master-Master and Master-Standby configuration, we should follow these steps to avoid this symptom:
    1. Configure VRRP for Master-Master and Master-Standby
    2. Configure master-redundancy only at Master-Master side only, then reboot Master-Master. (When I configure master-redundncy on Master-Master and Master-Standby at the same time and rebooted both controllers, never be successful)
    3. After Master-Master comes up, configure master-redundancy on Master-Standby. This is important - because - If Master-Standby already became a pair of master-redundancy, I could not change the configuration. Only if I keep Master-Standby as Master controller, I could configure master-redundancy.
    4. Reboot Master-Standby
    5. If show run does not work or WebUI does not work, reboot the controller which the symptom resides in.
    Everyone, have you experienced such a symptom before?
  • 12.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 06:09 AM
    Not seen it before to do with code. Please post your whole configs as I asked previously.
  • 13.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 06:17 AM
    Any controller that has a master-backup master or master-local relationship will say STM busy until it establishes connectivity with its parent controller.  Those controllers need to reach steady state before anything is done on the commandline.
    The console does come up and allow you to login before it is ready to execute any commands.  If the controller says STM busy after it reaches steady state, you need to open a case so your configuration can be troubleshot in detail.
  • 14.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 09:38 AM
    Hi cjoseph,
    When this symptom happens, "STM Busy" as a response of "show run" more than 1 hour.
    Also, if this symptom does not happen, "show run" responded after 3 minutes of boot completion.
    Therefore, I had to admit that there was something abnormal going on.
    My assumtion is - two IPSEC tunnels between Master-Master and Master-Standby controller
    might cause routing problem inside of the controller, therefore internal application's communication
    such as task-task communication (semaphore) cannot be performed. STM might be trying to do
    something, but because of abnormal condition, STM had to wait.
    My focus today is to try to determine internal tcp communication and route. If there is a command
    to display STM's socket number and peer ip address, it i much helpful, but I do not know what that command
    is. I will try to find by myself.
    If you know a command to display internal application's communication status (port number and peer ip address)
    it is much helpful.
    Hi The.racking.monkey,
    I am going to paste Master-Master and Master-Standby configuration.
    Apologies that I had to mask admin's password and ike secret.
    I just configured VLAN1 IP address, VRRP 10, and master-redundancy.
    version 5.0
    enable secret "******"
    hostname "Master-Master"
    clock timezone EST -5
    masterip 0.0.0.0
    location "Building1.floor1"
    mms config 0
    controller config 0
    ip access-list eth validuserethacl
      permit any
    netservice svc-snmp-trap udp 162
    netservice svc-netbios-dgm udp 138
    netservice svc-dhcp udp 67 68
    netservice svc-smb-tcp tcp 445
    netservice svc-https tcp 443
    netservice svc-ike udp 500
    netservice svc-l2tp udp 1701
    netservice svc-syslog udp 514
    netservice svc-pptp tcp 1723
    netservice svc-telnet tcp 23
    netservice svc-http-accl tcp 88
    netservice svc-sccp tcp 2000
    netservice svc-sec-papi udp 8209
    netservice svc-tftp udp 69
    netservice svc-kerberos udp 88
    netservice svc-sip-tcp tcp 5060
    netservice svc-netbios-ssn tcp 139
    netservice svc-pop3 tcp 110
    netservice svc-adp udp 8200
    netservice svc-cfgm-tcp tcp 8211
    netservice svc-noe udp 32512
    netservice svc-http-proxy3 tcp 8888
    netservice svc-lpd-tcp tcp 631
    netservice svc-dns udp 53
    netservice svc-msrpc-tcp tcp 135 139
    netservice svc-rtsp tcp 554
    netservice svc-http tcp 80
    netservice svc-vocera udp 5002
    netservice svc-h323-tcp tcp 1720
    netservice svc-h323-udp udp 1718 1719
    netservice svc-nterm tcp 1026 1028
    netservice svc-sip-udp udp 5060
    netservice svc-http-proxy2 tcp 8080
    netservice svc-papi udp 8211
    netservice svc-noe-oxo udp 5000 alg noe
    netservice svc-ftp tcp 21
    netservice svc-natt udp 4500
    netservice svc-svp 119
    netservice svc-microsoft-ds tcp 445
    netservice svc-gre 47
    netservice svc-smtp tcp 25
    netservice svc-smb-udp udp 445
    netservice svc-sips tcp 5061
    netservice svc-netbios-ns udp 137
    netservice svc-esp 50
    netservice svc-cups tcp 515
    netservice svc-bootp udp 67 69
    netservice svc-snmp udp 161
    netservice svc-v6-dhcp udp 546 547
    netservice svc-icmp 1
    netservice svc-ntp udp 123
    netservice svc-msrpc-udp udp 135 139
    netservice svc-ssh tcp 22
    netservice svc-http-proxy1 tcp 3128
    netservice svc-v6-icmp 58
    netservice svc-lpd-udp udp 631
    ip access-list session allow-diskservices
      any any svc-netbios-dgm permit
      any any svc-netbios-ssn permit
      any any svc-microsoft-ds permit
      any any svc-netbios-ns permit
    ip access-list session control
      user any udp 68 deny
      any any svc-icmp permit
      any any svc-dns permit
      any any svc-papi permit
      any any svc-sec-papi permit
      any any svc-cfgm-tcp permit
      any any svc-adp permit
      any any svc-tftp permit
      any any svc-dhcp permit
      any any svc-natt permit
    ip access-list session validuser
      any any any permit
      any any any permit
    ip access-list session vocera-acl
      any any svc-vocera permit queue high
    ip access-list session icmp-acl
    ip access-list session captiveportal
      user   alias controller svc-https dst-nat 8081
      user any svc-http dst-nat 8080
      user any svc-https dst-nat 8081
      user any svc-http-proxy1 dst-nat 8088
      user any svc-http-proxy2 dst-nat 8088
      user any svc-http-proxy3 dst-nat 8088
    ip access-list session allowall
      any any any permit
    ip access-list session sip-acl
      any any svc-sip-udp permit queue high
      any any svc-sip-tcp permit queue high
    ip access-list session https-acl
      any any svc-https permit
    ip access-list session dns-acl
    ip access-list session allow-printservices
      any any svc-cups permit
      any any svc-lpd-tcp permit
      any any svc-lpd-udp permit
    ip access-list session logon-control
    ip access-list session vpnlogon
      user any svc-ike permit
      user any svc-esp permit
      any any svc-l2tp permit
      any any svc-pptp permit
      any any svc-gre permit
    ip access-list session srcnat
      user any any src-nat
    ip access-list session skinny-acl
      any any svc-sccp permit queue high
    ip access-list session tftp-acl
    ip access-list session cplogout
    ip access-list session dhcp-acl
    ip access-list session http-acl
      any any svc-http permit
    ip access-list session ap-uplink-acl
      any any udp 68 permit
      any host 224.0.0.251 udp 5353 permit
    ip access-list session ap-acl
      any any svc-syslog permit
      any user svc-snmp permit
      user any svc-http permit
      user any svc-http-accl permit
      user any svc-smb-tcp permit
      user any svc-msrpc-tcp permit
      user any svc-snmp-trap permit
      user any svc-ntp permit
      user   alias controller svc-ftp permit
    ip access-list session svp-acl
      any any svc-svp permit queue high
      user host 224.0.1.116 any permit
    ip access-list session noe-acl
      any any svc-noe permit queue high
    ip access-list session h323-acl
      any any svc-h323-tcp permit queue high
      any any svc-h323-udp permit queue high
    ipv6 access-list session v6-icmp-acl
      any any svc-v6-icmp permit
    ipv6 access-list session v6-https-acl
    ipv6 access-list session v6-dhcp-acl
      any any svc-v6-dhcp permit
    ipv6 access-list session v6-dns-acl
    ipv6 access-list session v6-allowall
      any any any permit
    ipv6 access-list session v6-http-acl
    ipv6 access-list session v6-logon-control
    vpn-dialer default-dialer
      ike authentication PRE-SHARE ******
    user-role ap-role
     session-acl control
     session-acl ap-acl
    user-role default-vpn-role
     session-acl allowall
     ipv6 session-acl v6-allowall
    user-role voice
     session-acl sip-acl
     session-acl noe-acl
     session-acl svp-acl
     session-acl vocera-acl
     session-acl skinny-acl
     session-acl h323-acl
     session-acl dhcp-acl
     session-acl tftp-acl
     session-acl dns-acl
     session-acl icmp-acl
    user-role default-via-role
    user-role guest-logon
     captive-portal "default"
     session-acl logon-control
     session-acl captiveportal
    user-role guest
     session-acl http-acl
     session-acl https-acl
     session-acl dns-acl
     ipv6 session-acl v6-http-acl
     ipv6 session-acl v6-https-acl
     ipv6 session-acl v6-dhcp-acl
     ipv6 session-acl v6-icmp-acl
     ipv6 session-acl v6-dns-acl
    user-role stateful-dot1x
    user-role authenticated
    user-role logon
     session-acl vpnlogon
     ipv6 session-acl v6-logon-control
    no spanning-tree
    interface mgmt
            shutdown
    dialer group evdo_us
      init-string ATQ0V1E0
      dial-string ATDT#777
    dialer group gsm_us
      init-string AT+CGDCONT=1,"IP","ISP.CINGULAR"
      dial-string ATD*99#
    dialer group vivo_br
      init-string AT+CGDCONT=1,"IP","zap.vivo.com.br"
      dial-string ATD*99#
    interface gigabitethernet  1/0
            description "GE1/0"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet  1/1
            description "GE1/1"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet  1/2
            description "GE1/2"
            trusted
            trusted vlan 1-4094
    interface gigabitethernet  1/3
            description "GE1/3"
            trusted
            trusted vlan 1-4094
    interface vlan 1
    master-redundancy
      master-vrrp 10
      peer-ip-address 172.200.1.207 ipsec **********************************************
    vrrp 10
      priority 150
      vlan 1
      preempt
      no shutdown
    ip default-gateway 172.200.0.1
    ap mesh-recovery-profile cluster RecoveryiWFjpGRjGG7S0s6q wpa-hexkey 625880ae9103527d34c679f3e598c50a12ea8de08dc33bdd2a2cf2d8da7ec9619cf38e81fe54b69357a819d18e6aaff6a3036ca347159c13d78ba9f21e8bfb0e640da8b6185b285a5645b3008ad89ffa
    wms
     general poll-interval 60000
     general poll-retries 3
     general ap-ageout-interval 30
     general sta-ageout-interval 30
     general learn-ap disable
     general persistent-known-interfering enable
     general propagate-wired-macs enable
     general stat-update enable
     general collect-stats disable
    crypto isakmp policy 20
      encryption aes256
    crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
    crypto dynamic-map default-dynamicmap 10000
      set transform-set default-transform default-aes
    vpdn group l2tp
    ip dhcp default-pool private
    vpdn group pptp
    mux-address 0.0.0.0
    adp discovery enable
    adp igmp-join enable
    adp igmp-vlan 0
    voip prioritization disable
    voip rtcp-inactivity disable
    voip sip-midcall-req-timeout disable
    ssh mgmt-auth username/password
    mgmt-user admin root ****************************************
    database synchronize period 60
    database synchronize rf-plan-data
    ip mobile domain default
    ip igmp
    no firewall attack-rate cp 1024
    firewall cp
    firewall cp
    no acceleration cifs caching
    no acceleration cifs chattiness
    no acceleration cifs read-ahead
    no acceleration cifs write-behind
    no acceleration http authentication
    no acceleration http caching
    no acceleration http deduplication
    no acceleration http post
    no acceleration http sharepoint
    no acceleration mapi aggregation
    no acceleration mapi caching
    no acceleration mapi prefetching
    packet-capture-defaults tcp disable udp disable sysmsg disable other disable
    ip domain lookup
    country US
    aaa authentication mac "default"
    aaa authentication dot1x "default"
    aaa server-group "default"
     auth-server Internal
     set role condition role value-of
    aaa authentication via connection-profile "default"
    aaa authentication via web-auth "default"
    aaa authentication via global-config
    aaa profile "default"
    aaa authentication captive-portal "default"
    aaa authentication wispr "default"
    aaa authentication vpn "default"
    aaa authentication vpn "default-rap"
    aaa authentication mgmt
    aaa authentication stateful-ntlm "default"
    aaa authentication stateful-kerberos "default"
    aaa authentication stateful-dot1x
    aaa authentication via auth-profile "default"
    aaa authentication wired
    web-server
    papi-security
    guest-access-email
    control-plane-security
    voice dialplan-profile "default"
    voice sip
    aaa password-policy mgmt
    ap system-profile "default"
    ap regulatory-domain-profile "default"
       country-code US
       valid-11g-channel 1
       valid-11g-channel 6
       valid-11g-channel 11
       valid-11a-channel 36
       valid-11a-channel 40
       valid-11a-channel 44
       valid-11a-channel 48
       valid-11a-channel 149
       valid-11a-channel 153
       valid-11a-channel 157
       valid-11a-channel 161
       valid-11a-channel 165
       valid-11g-40mhz-channel-pair 1-5
       valid-11g-40mhz-channel-pair 7-11
       valid-11a-40mhz-channel-pair 36-40
       valid-11a-40mhz-channel-pair 44-48
       valid-11a-40mhz-channel-pair 149-153
       valid-11a-40mhz-channel-pair 157-161
    ap wired-ap-profile "default"
    ap enet-link-profile "default"
    ap mesh-ht-ssid-profile "default"
    ap mesh-cluster-profile "default"
    ap wired-port-profile "default"
    ap mesh-radio-profile "default"
    ids general-profile "default"
    ids unauthorized-device-profile "default"
    ids profile "default"
    rf arm-profile "default"
    rf optimization-profile "default"
    rf event-thresholds-profile "default"
    rf dot11a-radio-profile "default"
    rf dot11g-radio-profile "default"
    wlan dot11k-profile "default"
    wlan voip-cac-profile "default"
    wlan ht-ssid-profile "default"
    valid-network-oui-profile
    wlan edca-parameters-profile station "default"
    wlan edca-parameters-profile ap "default"
    wlan ssid-profile "default"
    wlan virtual-ap "default"
    ap provisioning-profile "default"
    ap-group "default"
    snmp-server enable trap
    process monitor log
    end
    (Master-Master) #
  • 15.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 09:40 AM
    Here is Master-Standby configuration.
    (Master-Standby) #show run
    version 5.0
    hostname "Master-Standby"
    masterip 0.0.0.0
    mms config 0
    controller config 0
      permit any
      any any any permit
      any any any permit
      any any any permit
      any any any permit
    user-role ap-role
     session-acl control
     session-acl ap-acl
    user-role voice
     session-acl sip-acl
     session-acl noe-acl
     session-acl svp-acl
     session-acl dns-acl
    user-role guest
     session-acl dns-acl
    user-role logon
    no spanning-tree
    interface mgmt
            shutdown
    dialer group gsm_us
      dial-string ATD*99#
      dial-string ATD*99#
            description "GE1/0"
            trusted
            trusted vlan 1-4094
            description "GE1/1"
            trusted
            trusted vlan 1-4094
            description "GE1/2"
            trusted
            trusted vlan 1-4094
            description "GE1/3"
            trusted
            trusted vlan 1-4094
    interface vlan 1
    master-redundancy
      master-vrrp 10
      peer-ip-address 172.200.1.206 ipsec ***************************************************
    vrrp 10
      vlan 1
      preempt
      no shutdown
    ap mesh-recovery-profile cluster RecoveryiWFjpGRjGG7S0s6q wpa-hexkey 34286188d9209a09db797329a81e293ab0b7fb70c23d2ab13b3438372f56f9ed8d26ca9f6125932da1aa4e82221b4e928702c736dcaef15881cf3524d8739ccdf880b6d73199d00530c115c144298b68
    wms
      encryption aes256
    vpdn group l2tp
    vpdn group pptp
    mux-address 0.0.0.0
    adp igmp-vlan 0
    mgmt-user admin root *******************************************************************
    no database synchronize
    ip igmp
    firewall cp
    firewall cp
    ip domain lookup
    country US
    web-server
    papi-security
    guest-access-email
    voice sip
       country-code US
       valid-11g-channel 1
       valid-11g-channel 6
    ap-group "default"
    process monitor log
    end
    (Master-Standby) #
  • 16.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 09:42 AM
    Mike8877,
    Unfortunately, the config only shows how the device is configured and does not show the device's response to the the environment with that configuration.
    On another note, to see the sockets, you would do a "show netstat'
  • 17.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 11:18 AM
    I changed boot image from 5.0.4.6 to 6.1.1.0(Native image came with 3400 controller)
    and found that this symptom does not occur in 6.1.1.0
    It seems that 6.1.1.0 code does not create ipsec connection between Master-Master and Master-Standby, if there is already established.
    BUT - I found 6.1.1.0 has serious problem.
    With this Master-Master and Master-Standby configuration, 6.1.1.0 code does not display Config - Controller.
    Config - Controller is very important to configure IKE shared secret between Master and Local controller.
    Therefore I gave up 6.1.1.0 code.
    Because I have to stay at 5.0.4.6 code, I am going to find a best practice how to power on Master-Master and Master-Local.
    in show crypto ipsec sa screen, Initiator seems to be the controller which first came up.
    So, best practice would be (1) Power on Master-Master and wait for boot completion. Wait additional 5 minutes (2) Power on Master-Standby  (3) Check show crypto ipsec sa and confirm if there is only one ipsec between Master-Master and Master-Standby.
  • 18.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 11:22 AM
    To be clear 6.1.1.0 should not be used....  Please use the latest 6.1.3.x
    Also, please open a case in parallel to get all your questions answered, specific to your use case.
  • 19.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 12:51 PM
    I tested 6.1.3.1 but Configure - Controller was not displayed. Even I went through Controller Wizard then rebooted, Configure-Controller was not displayed. Therefore I am going back to 5.0.4.6. With 5.0.4.6 I will find a good method to boot Master-Master and Master-Standby controllers.
  • 20.  RE: VLAN1 should not be used for Master-Master VRRP??
    Posted May 04, 2012 04:28 PM
    A few points:
    When you upgrade/downgrade, you need to clear your browser cache to make sure that everything displays correctly.
    Next, if you are configuring a controller through Configuration> Controller and pointing it at an ip address, that forms a master/local pair and not a master/backup master pair.  Master redundancy is configured in Configuration> Advanced Services> Redundancy.
    The STM is definitely when a local controller has not found its master controller or has not connected with it yet.
    Please contact support, if you have not done this already to walk you through what you need to do.
