Comware
Vlans across four switches
  • 1.  Vlans across four switches
    Posted Dec 04, 2011 05:36 AM
    Have a 1810-48G switch that has 3 1810-24G switches connected to it via GBIC's fibre. I need to setup 5 vlans on these switches to create 5 different networks.
    Looking at:
    ID: 1 DEFAULT_VLAN
     20 Library
     30 Lighting
     40 Sound
     50 Guest
    1810-24              1810-24              1801-48                      1810-24
    XXXX -  - - - - - - - XXXXX - - - - - -   XXXXXXX - - - - - - - - -XXXXX
    sw1                       sw2                     sw3                               sw4
    As mentioned, there need to be 5 vlans.  I need to make sure I get three vlans from sw1 to sw4. Is it just a matter of creating the vlans and allocating the ports to the vlans? Any other taggin having to be done?
    Matt
    #tagging
    #1810
    #multipleswitches
    #vlans
  • 2.  RE: Vlans across four switches
    Posted Dec 06, 2011 01:49 AM
    Does anyone have any idea? I have created the VLAN's but cannot ping from sw1 to sw4 with a vlan. Deafult vlan works fine. Does the GBICS automatically carry the vlans, or do these have to be tagged?
