VM Mobility controller stand alone
  • 1.  VM Mobility controller stand alone
    Posted Jan 07, 2020 04:29 PM
    Hello Guys
    I installed a  Mobility controller in stand alone on a virtual machine
    I installed the fallowing licenses on the controller on stand alone
    AP,PEF, RFP, and  MC-VA-US
    This is for  a LAB and i got these license for lab purpuses demo licenses.
    The thing is that the AP wont go up and its telling me that it has no license... even if i can see that all the license are installed and witht he check mark
    Its telling me its not using any license.
    I did the same with a physical controller with a ap pef and a rfp license and worked fine no issue.
    Now i was wondering  it says MC-VA-US but my ap is RW,  is there any issue with this?? or any ideas what could be the problem?
    Cheers
    Carlos
  • 2.  RE: VM Mobility controller stand alone
    MVP EXPERT
    Posted Jan 07, 2020 05:22 PM
    I think (all most sure;)) this make sence and you have to use the same regulator domain. Dont mix MC-VA-US license with AP-RW access points. Can you install a MC-VA-RW licence?
  • 3.  RE: VM Mobility controller stand alone
    Posted Jan 08, 2020 04:12 PM
    Thats really odd beacuse my SE gave me those licenses....
    Any from aruba can confirm if MC-VA-US vm controller does not work with RW aps ?
    Cheers
    Carlos
  • 4.  RE: VM Mobility controller stand alone
    MVP EXPERT
    Posted Jan 08, 2020 04:38 PM
    Iam sure your SE pick the wrong one ;) ...Or if your are live in US you have the wrong AP.
    https://www.arubanetworks.com/techdocs/ArubaOS_83x_Web_Help/Content/PDFs/ArubaOS_8.3.0.x_Licensing_Guide.pdf
  • 5.  RE: VM Mobility controller stand alone
    Posted Jan 09, 2020 03:05 AM
    Can you share the output of show ap database?
  • 6.  RE: VM Mobility controller stand alone
    Posted Jan 10, 2020 08:47 AM
    Hello Marcell, im asking for the RW license, thanks.
    Ajay
    Here is the output for you, its like it has no license, so its icative aka... 2IL
    (VM1) [mynode] #show ap database
    AP Database
    Name         Group         AP Type  IP Address    Status    Flags  Switch IP       Standby IP
    AP_215_TEST  WIFI_TEST  215      172.16.151.2  Up 3m:4s  2IL    172.16.150.250  0.0.0.0
    Flags: 1 = 802.1x authenticated AP use EAP-PEAP; 1+ = 802.1x use EST; 1- = 802.1x use factory cert; 2 = Using IKE version 2
           B = Built-in AP; C = Cellular RAP; D = Dirty or no config
           E = Regulatory Domain Mismatch; F = AP failed 802.1x authentication
           G = No such group; I = Inactive; J = USB cert at AP; L = Unlicensed
           M = Mesh node
           N = Duplicate name; P = PPPoe AP; R = Remote AP; R- = Remote AP requires Auth;
           S = Standby-mode AP; U = Unprovisioned; X = Maintenance Mode
           Y = Mesh Recovery
           c = CERT-based RAP; e = Custom EST cert; f = No Spectrum FFT support
           i = Indoor; o = Outdoor; s = LACP striping; u = Custom-Cert RAP; z = Datazone AP
           p = In deep-sleep status
           4 = WiFi Uplink
    Total APs:1
    (VM1) [mynode] #
