VMC 8.1 DHCP relay issue.
  • 1.  VMC 8.1 DHCP relay issue.
    Posted Oct 17, 2017 03:53 AM
    Hi guy,
    I have the scenario below that client cannot obtian IP from router (act as DHCP server). If PC is in same network of VLAN2, it can access to internet.
    I also make the controller act as DHCP server and gatway point to Router. This also did not work for wireless client;.
    VLAN 1 Managaemnt
    VLAN 2 Guest (Role Logon)
  • 2.  RE: VMC 8.1 DHCP relay issue.
    Posted Oct 18, 2017 07:56 AM
    • Are the routing ok between your vlans ?
    • Does the clients be able to reach the router ?
    • Why you are not using the Aruba as DHCP server ?
    Thanks in advance for your feedback.
  • 3.  RE: VMC 8.1 DHCP relay issue.
    Posted Oct 20, 2017 03:05 AM
    - Yes, routing is running on router. I tested on only one vlan and the result is the same.
    - Yes, clients reached the router and it shown log from correctly source.
    - I tested with DHCP server enable on the controller but client will not reach to the router.
    I think the root cause is at the controller because wired network can access to the internet as well.
  • 4.  RE: VMC 8.1 DHCP relay issue.
    Posted Oct 26, 2017 09:57 AM
    Hi, here nearly the same problem.
    New Controller installed with 8.1, now on 8.2 on VMware.
    All VLANs are tagged forwarded to VMC and APs.
    Firewall or Windows Server is DHCP depending on Network.
    First step only WPA2 personal.
    No problems with default vlan untagged.
    I added a IPv4 address to the VLAN and set DHCP to none.
    When I connect to WiFi I can see in firewall log the DHCP Offer and discover (incoming from correct VLAN 90) But Smartphone get no IP.
    When I change to DHCP Helper Address I can see in firewall request and ack with information tht it comes from configured helper address.
    Again no IP at the client.
    Windows Client get ip addresses with cable connections in untagged vlans.
    interface gigabitethernet 0/0/0
        description "GE0/0/0"
        trusted
        trusted vlan 1-4094
        no poe
        switchport mode trunk
        switchport access vlan 90
        no spanning-tree
    wlan virtual-ap "company-VW"
        aaa-profile "company-VW"
        vlan OfficeLAN
        ssid-profile "company-VW"
    aaa profile "company-VW"
        authentication-dot1x "company-VW"
        enforce-dhcp
    wlan ssid-profile "company-VW"
        essid "company-VW"
        opmode wpa2-psk-aes
        wpa-passphrase ...
    Any idea?
