VMC interfaces
  • 1.  VMC interfaces
    Posted Feb 12, 2019 04:52 AM
    I'm about to start a AOS8 virtual installation (no MM involved) and just wondering which interfaces are available for configuration? are they stil named the same as the old system - interface gigabitethernet 0/0/0 etc.
    Cheers
  • 2.  RE: VMC interfaces
    Posted Feb 12, 2019 05:37 AM
  • 3.  RE: VMC interfaces
    Posted Feb 12, 2019 05:42 AM
    Hi Thanks, so the naming convention is the same, how many are available? bearing in mind they are virtual not hardware.
    Matt
  • 4.  RE: VMC interfaces
    Posted Feb 12, 2019 05:47 AM
    I will update you.
  • 5.  RE: VMC interfaces
    Posted Feb 21, 2019 04:22 PM
    @MDRF,
    Interface breaks down like this, the left side is the VMWare Interface name, and the right side is the corresponding VMM/VMC interface
    Virtual Mobility Master: 2 Network Interfaces, 1 OOB
    Network Adapter 1 = mgmt (OOB)
    Network Adapter 2 = gig0/0/0
    Network Adapter 3 = gig0/0/1
    Virtual Mobility Controller: 3 Network Interfaces, 1 OOB
    Network Adapter 2 = gig0/0/1
    Network Adapter 3 = gig0/0/2
    Network Adapter 4 = gig0/0/3
    DO NOT delete or rename or reorder these interfaces or it will break the internal mapping and the VMM or VMC will have to be re-deployed.
  • 6.  RE: VMC interfaces
    Posted Feb 22, 2019 09:38 AM
    Thanks jhoward, much appreciated.
    Matt
