Network Management
VMC on Hyper-v ip address stops responding
This thread has been viewed 40 times
  • 1.  VMC on Hyper-v ip address stops responding
    Posted Apr 23, 2021 12:22 PM
    I have VMM setup and running reliably. I've taken the same steps in Hyper-V (Windows 10 Pro 64bit on HPE Proliant G8 360DL) for VMC and initially the VMC will ping it's gateway but if I come back to it hours later no response by ping the the VMM shows the controller as off line.
    Does Aruba support VirtualBox at all?
  • 2.  RE: VMC on Hyper-v ip address stops responding
    MVP EXPERT
    Posted Apr 25, 2021 01:22 PM
    VMC is supported on;
    • Hyper-V Version Windows Server 2012 R2 or 2016.
    • VMware 6.5
    • KVM Hypervisor
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/install-guide/virt-appl/inst-aos-wind-hypv.htm
    Marcel Koedijk | MVP Guru 2021 | ACMP | ACCP | ACDA | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 3.  RE: VMC on Hyper-v ip address stops responding
    Posted Apr 26, 2021 12:02 PM
    Hi
    Yes you can deploy on VirtualBox
    Tharindu Pamoda
  • 4.  RE: VMC on Hyper-v ip address stops responding
    Yes its Supporting VirtualBox
    Tharindu Pamoda
  • 5.  RE: VMC on Hyper-v ip address stops responding
    Tharindu Pamoda
  • 6.  RE: VMC on Hyper-v ip address stops responding
    Posted Apr 26, 2021 12:03 PM
    Yes it can deploy on VirtualBox
    Tharindu Pamoda
