VMC Scalability for IAP-VPN and Multizone
  • 1.  VMC Scalability for IAP-VPN and Multizone
    Posted Jun 14, 2018 10:06 PM
    Hi Airheads,
    Does anybody know where i can find sizing recommendation for using VMC as IAP-VPN termination or Multizone termination?
    Scott
  • 2.  RE: VMC Scalability for IAP-VPN and Multizone
    Posted Jun 14, 2018 10:59 PM
    EDIT
  • 3.  RE: VMC Scalability for IAP-VPN and Multizone
    Posted Jun 14, 2018 11:44 PM
    supported in 8.3
    Starting from ArubaOS 8.3.0.0, IAP-VPN is supported on Mobility Controller Virtual Appliance by using default
    self-signed certificate (Aruba PKI). For Instant AP to establish IPsec connection with Mobility Controller Virtual
    Appliance, the controller presents a default self-signed certificate which is uploaded on the Instant AP using
    Activate.
    Through Activate, you can push only one default self-signed certificate to Instant AP which can be used to establishIPsec tunnel with Mobility Controller Virtual Appliance.
  • 4.  RE: VMC Scalability for IAP-VPN and Multizone
    Posted Jun 05, 2019 05:48 AM
    Can the certificate be deployed via Airwave in read-write mode with Groups? I deployed automatically 500 IAPs with Airwave group template on a network without connectivity to Activate. The VPN connection is a secondary usage, the control plane does not need it to contact Airwave. So, can I configure that IAP-VPN against a VMC AOS8.5 if I deploye the self-signed cert from Airwave itself?
    These are the options available on Airwave for the IAP group configuration:
    CA Cert:
    Server Cert:
    Captive Portal Cert:
    Captive Portal Logo: only show less than 16k bytes logo files
    RadSec Server Cert:
    RadSec CA Cert:
    Web Cert:
    Custom SSL Cert:
  • 5.  RE: VMC Scalability for IAP-VPN and Multizone
    Posted Sep 10, 2020 12:22 AM
    **BUMP**
    never got a reply to this and now i'm finding myself asking the same question!!
    Anybody?
