vMM on AOS 8.6.0.0 - WebCC license applied - need help to enable it?
  • 1.  vMM on AOS 8.6.0.0 - WebCC license applied - need help to enable it?
    Posted Jan 01, 2020 10:54 PM
    I have a Virtual Mobility Master running AOS 8.6.0.0.
    I then have several Aruba 7030 Mobility Controllers, also on 8.6.0.0.
    We've purchased the WebCC license, and I've added this license to the Mobility Master.
    (ArubaMM-VA_C4_26_6E) ^[mynode] #show license summary
    Thu Jan 02 14:49:27.868 2020
    License Summary
    License Description Status Expiration Total Installed
    AP Access Points Active Never 48
    PEFNG Policy Enforcement Firewall Active Never 48
    RFP RF Protect(WIP,Spectrum,Multi-zone) Active Never 48
    ACR Advanced Cryptography Not Licensed Not Licensed 0
    WebCC Web Content Classification Active 2030-01-02 00:00:50 48
    MM Mobility Master Virtual Appliance Active Never 50
    MC-VA-RW Controller Virtual Appliance(RW) Not Licensed Not Licensed 0
    MC-VA-EG Controller Virtual Appliance(EG) Not Licensed Not Licensed 0
    MC-VA-IL Controller Virtual Appliance(IL) Not Licensed Not Licensed 0
    MC-VA-JP Controller Virtual Appliance(JP) Not Licensed Not Licensed 0
    MC-VA-US Controller Virtual Appliance(US) Not Licensed Not Licensed 0
    VIA VIA VPN Client(Session-based) Not Licensed Not Licensed 0
    On the Mobility Master, I selected Managed Network on the left, then went into Configuration, Services, and Firewall.
    I then made sure that "Enable firewall visiblity", "Enable deep packet inspection", and "Enable web content classifcation" were all checked/enabled.
    I applied these changes, and even rebooted (reloaded) one of the mobility controllers.
    However, if I use the CLI, WebCC still seems to be disabled?
    (ArubaMM-VA_C4_26_6E) ^[mynode] #show web-cc status
    Thu Jan 02 14:51:48.042 2020
    Web Content Classification Status
    Service                               Status
    Web Content Classification enabled :  No
    DNS/Name Server configured :          No
    URL Cloud lookup server reachable :   No
    Any ideas what's going on?
    What else do I need to do to get WebCC working?
  • 2.  RE: vMM on AOS 8.6.0.0 - WebCC license applied - need help to enable it?
    Posted Jan 02, 2020 12:04 AM
    The MM needs Internet access and DNS needs to be configured on it. Have these been done?
  • 3.  RE: vMM on AOS 8.6.0.0 - WebCC license applied - need help to enable it?
    Posted Jan 02, 2020 10:23 AM
    did you enabled the License?
    DNS is manadatory and you need to allow https traffic to aruba.brightcloud.com
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-Enable-the-installed-licenses-on-Mobility-Master-running/ta-p/292858
  • 4.  RE: vMM on AOS 8.6.0.0 - WebCC license applied - need help to enable it?
    Posted Jan 12, 2020 02:19 PM
    The suggestion about DNS was correct.
    Even though we could do DNS lookups on the MM itself, it seems you need to set the below specifically for WebCC to work.
    For the benefit of others, these are the commands we used to get it working:
    (ArubaMM-VA_EA_F5_7F) [mynode] #cd /mm
    (ArubaMM-VA_EA_F5_7F) [mm] #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (ArubaMM-VA_EA_F5_7F) [mm] (config) #ip domain lookup
    Operation will not take effect until a reboot.
    (ArubaMM-VA_EA_F5_7F) [mm] (config) #ip name-server 8.8.8.8
    (ArubaMM-VA_EA_F5_7F) ^[mm] (config) #write memory
    Saving Configuration...
