Vocera Guide
  • 1.  Vocera Guide
    Posted Oct 16, 2013 09:44 AM
    We will be doing a demo of the Vocera badges. Is there a Vocera guide? Is there anything that can be tricky with the configuration?
  • 2.  RE: Vocera Guide
    Posted Oct 16, 2013 09:55 AM
    Aruba controller has a ALG for vocera so it should able to detect it from a firewall perspective , make sure that on the SSID you have the lower data rates enabled
    There's already a Vocera ACL available on the controllers:
    Make sure you read this document  which has some good tips to allow Voice devices to roaming appropriately on wireless:
    http://www.arubanetworks.com/wp-content/uploads/DG_Roaming.pdf
    http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/Voice_Video.php
    And also Vocera has best practices to work properly on wireless :
    http://www.vocera.com/products/documents/InfrastructureGuide.pdf
  • 3.  RE: Vocera Guide
    Posted Oct 16, 2013 10:23 AM
    I have found a Design and Implementation Guide on the Aruba sight but it seems a little dated.
  • 4.  RE: Vocera Guide
    Posted Oct 16, 2013 10:09 AM
    Check out this link for a full guide: http://www.vocera.com/products/documents/InfrastructureGuide.pdf
    Check out this link for a summary guide: http://www.vocera.com/assets/pdf/documents/Vocera_IPGP_Summary.pdf
    They should point you in the right direction.
    Also, in this post: http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Vocera-ACL/td-p/48080 cjoseph mentions that Aruba's Roaming Devices VRD has a template for Vocera.
    I just went through tweaking my Vocera network about a year ago.
