Wired Intelligent Edge
Voice and Data vlan DHCP issues
  • 1.  Voice and Data vlan DHCP issues
    Posted Apr 26, 2019 09:48 PM
    Hi
    I am trying to setup a for NEC VoIP phones that will feed the users PC
    What happens when we test with laptops , No IP phones yet, is we get the DHCP from the Voice vlan, even when we untag the voice vlan
    Am I missing any commands?   or should I wait for phones to test further
    For the vlan configs I have below(Comments in )
    Vlan 100              (Range 10.1.100.0/24)
    name "Data"
    Untagged 1-24
    Tagged 48-52    (All trunk Ports)
    no ip address
    ip helper-address 10.1.100.1  (Fortinet Router configured for DHCP)
    exit
    Vlan 110  (Range 10.1.110.0/24)
    Name "Voice"
    tagged 1-24 ,48-52
    no ip address
    ip helper-address 10.1.110.10   (NEC Voice server)
    Voice  (declared as Voice Vlan)
    Exit
    Thanks Much
    Craig
  • 2.  RE: Voice and Data vlan DHCP issues
    Posted Apr 27, 2019 03:04 AM
    It’s not needed to set a IP helper when the dhcp server is in the same segment. Also the ip helper address is useless because there is no ip interface at this switch.
    I suppose that the nec voice server is attached to the data vlan. Is the voice server also connected at this switch?
  • 3.  RE: Voice and Data vlan DHCP issues
    Posted Apr 27, 2019 11:25 AM
    Thanks,  I am sure the NEC team connected the voice server to a tagged voice, untagged data port  I can check   Also I will try adding an IP interface for the data vlan
    Craig
  • 4.  RE: Voice and Data vlan DHCP issues
    Posted Apr 27, 2019 12:04 PM
    Try to connect the server to an untagged voice port and remove the data vlan from the port. In most cases voice server are sending untagged traffic
