Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
  • 1.  Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 12, 2015 07:42 AM
    Hi Experts,
    we have deployed AP225 with 7210 controller however after implementation , clients are claiming that there voice calls are getting dropped after some time. It was working before this deployment.
    we have been getting lot of logs as below :
    pening /proc/sys/dev/wifi0/active_voice_client : No such file or directory
    Oct 12 06:41:40 :304055:  <ERRS> |AP stm| |ap| Unexpected stm (Station management) runtime error at stm_sysctl_write_param, 10460, Error opening /proc/sys/dev/wifi0/active_voice_client : No such file or directory
    Oct 12 08:05:18 :304055:  <ERRS> |AP  stm| |ap| Unexpected stm (Station management) runtime error at stm_sysctl_write_param, 10460, Error opening /proc/sys/dev/wifi0/active_voice_client : No such file or directory
    Oct 12 08:05:51 :304055:  <ERRS> |AP  stm| |ap| Unexpected stm (Station management) runtime error at stm_sysctl_write_param, 10460, Error opening /proc/sys/dev/wifi0/active_voice_client : No such file or directory
    Oct 12 08:25:20 :304055:  <ERRS> |AP  stm| |ap| Unexpected stm (Station management) runtime error at stm_sysctl_write_param, 10460, Error opening /proc/sys/dev/wifi0/active_voice_client : No such file or directory
    Oct 12 10:57:43 :304055:  <ERRS> |AP  stm| |ap| Unexpected stm (Station management) runtime error at stm_sysctl_write_param, 10460, Error opening /proc/sys/dev/wifi0/active_voice_client : No such file or directory
    Current code in controller is 6.4.2.9
    Can anybody please suggest me to fix this issue ?
    #7210
  • 2.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 12, 2015 07:52 AM
    What kind of voice clients are these?
    6.4.2.9 is older.  I would upgrade to 6.4.2.12 when you can for a possible fix.
  • 3.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 12, 2015 08:52 AM
    Spectralink phones 8400 are the voice clients.
    do we have any bug in 6.4.2.9 ?
  • 4.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 12, 2015 12:21 PM
    The controller itself does not drop calls or stop calls from going through, despite what those messages say.  I would look to ensure that the RF is tuned correctly.  Did you see the Spectralink portion of the Roaming VRD here?  http://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/20/1/Optimizing%20Aruba%20WLANs%20for%20Roaming%20Devices.pdf
  • 5.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 30, 2015 10:31 AM
    Sorry , I am reverting after long gap ... unfortunately we have still no solution on reported issue .
    we have designed and deployed based on attached VRD doc.
    As I mentioned not sure why are we getting below messages :
    Thanks in advance ...
  • 6.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 30, 2015 10:32 AM
    Did you try to open a TAC case so they can review your settings and environment?
  • 7.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 31, 2015 04:12 AM
    Hi ,
    I have opened TAC and working with them.
    so far no conclusion.
  • 8.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Oct 31, 2015 04:25 AM
    Well, that is the best thing to do.
    Is there any pattern to the drops?
    Did you install the system or someone else?
    How are your access points mounted?
    How far apart are your access points?
    Do you have "Drop Broadcast and Multicast" on all of your Virtual APs?
    Are you using encryption for that SSID?  What kind?
    How many SSIDs are you broadcasting?
    What is the maximum and minimum transmit power of your access points?
  • 9.  RE: Voice clients getting audio dropped after some time with controller 7210 and AP225 deployment
    Posted Apr 27, 2016 06:30 PM
    Do you have a solution? I have the same issue.
