You need to configure voice on the vlan.
for MTU, you need to change on the interface
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Dec 14, 2020 08:54 PM
Subject: Voice vlan config and jumbo frames on Cx switches
Hey,
I've been looking at the Cx documents at the voice feature command and I'm unsure how to apply voice vlan to access ports.
on the Cisco, switch port voice vlan ### gives the port that extra vlan what do we do on the cx? I've added voice to the vlan config, but I don't see how to add those vlans to the ports
re jumbo frames - for the 2930, we added jumbo to the wireless access point vlan.
I haven't found that in the docs yet for the Cx switches.
Any guidance? A sample config with WiFi aps, VoIP phones and downloadable user roles with clearpass would help a good bit.
Phillip Horn
