VOIP over WLAN with PEF
  • 1.  VOIP over WLAN with PEF
    Posted Jan 06, 2015 04:48 PM
    I have a 3400 controller with PEF installed. 1 SSID is setup with access to my local network with MAC-filtering enabled on that SSID, i have another SSID with just AES encryption.
    VOIP calls do not work when connected to the SSID with mac-filtering enabled. these VOIP calls do work when connected to the SSID with no mac-filtering.
    I dont see an option to check if traffic is getting blocked by the PEF that is causing these VOIP calls to fail.
    How can i tell if the VOIP calls are being blocked by the aruba PEF or if there is something else that is blocking VOIP?
  • 2.  RE: VOIP over WLAN with PEF
    Posted Jan 06, 2015 04:50 PM
    We will need some more information.
    - Do the phones register to the call server?
    - Does the phone receive an IP address?
    - Do you see traffic in the datapath session table? (show datapath session table <ip-of-phone>
    - What role is the phone getting?
    - Do you have firewall rules applied to the role other than allowall?
  • 3.  RE: VOIP over WLAN with PEF
    Posted Jan 06, 2015 05:48 PM
    I belive i found the issue, i had to allow sip over the SSID that had mac-filtering applied, voip over this SSID is working now.
    Thanks for the quick reply.
