VoIP phones dropping off network
  • 1.  VoIP phones dropping off network
    Posted Dec 02, 2015 02:39 PM
    I'm trying to test out deploying new AllWorx LLDP phones on some Aruba s2500 switches.  Right now if I connect them to my old switches the phones use LLDP-MED to determine the voip VLAN and are placed on the the correct vlan and work.
    I setup the same vlan on the s2500 that is connecitng back to the old switch using a trunk.  When I plug in the AllWorx phone, it shows up on the switch as a phone under show neighbors for about 30 seconds (I see the expiration time and it looks to be causing the drop).  It is pingable and on the correct vlan for about 10 seconds, then it drops and no longer has access and is no longer a neighbor device.  The symptoms are identical to this article http://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/WiredNetworks/article-id/4.
    I have followed through the article I listed and everything I can find on the KB.  Here are the configs I am running.
    vlan "15"
      description "VoIP"
    interface-profile voip-profile "VoIP-Profile"
      voip-vlan 15
      voip-dscp 46
      voip-dot1p 4
      voip-mode auto-discover
    interface-profile poe-profile "PoE-On"
      enable
    interface-profile lldp-profile "lldp-Profile"
      lldp transmit
      lldp receive
      med enable
      proprietary-neighbor-discovery
    interface-group gigabitethernet "Ethernet-Group"
      apply-to 0/0/0-0/0/11
      switching-profile "Voice-Port-Switching-Profile"
    I've got to be missing something here, any ideas?
    Thank You
  • 2.  RE: VoIP phones dropping off network
    Posted Dec 03, 2015 02:12 AM
    Can you provide details of  'Voice-Port-Switching-Profile' ?
    Also the KB you mentioned isn't accessible.
  • 3.  RE: VoIP phones dropping off network
    Posted Dec 03, 2015 10:03 AM
    Thank you for getting back to me.  It looks like I left a . in the URL.  The symptoms are the same, however this phone supports LLDP and CDP, I have tried manually setting both with the same results.  http://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/WiredNetworks/article-id/4 should get you in there.
    I have tried many different settings on the voip-switching-profile, everytime I am able to get the correct VLAN, correct IP address (pingable) then the connection expires and the phone goes offline, I believe it is being switched back to vlan1 but am not positive (30 seconds from LLDP detection).  The phone also stops showing up in show neighbor-devices after the expire time runs out.
    Currently the switching profile matches the default.  It is a access port, access / native vlans set to 1, trusted.
    Am I missing something in the switching profile? Thank you again for the response.
  • 4.  RE: VoIP phones dropping off network
    Posted Dec 03, 2015 11:32 AM
    This is what the interface status shows when the phone is booting up.
    ArubaS1500-12P) (VoIP profile "VoIP-Profile") #show lldp neighbor interface gigabitethernet 0/0/0 detail
    Interface: gigabitethernet0/0/0, Number of neighbors: 1
    Chassis id: 00:0a:dd:xx:xx:xx
    Interface description: Not received, ID: Port0
    Device MAC: 00:0a:dd:xx:xx:xx
    Last Update: Wed Dec  2 07:38:50 2015
    Time to live: 30, Expires in: 28 Secs
    System capabilities : Bridge,Phone
    Enabled capabilities: Bridge,Phone
    System name: Allworx 9212L
    System description:
      Allworx 9212L
    Auto negotiation: Supported, Enabled
    Autoneg capability:
      10Base-T, HD: yes, FD: yes
      100Base-T, HD: yes, FD: yes
    Media attached unit type: 100BaseTXFD - 2 pair category 5 UTP, full duplex mode (16)
    802.3 Power:
     Port ID:      Ifalias Port0
     Port Description: Not received
    LLDP-MED:
    Device Type:  Communication Device Endpoint (Class III)
    Capability:   LLDP-MED capabilities, Network policy
      Descr:        Voice
      Layer 2 Priority: 0
      DSCP Value:   0
  • 5.  RE: VoIP phones dropping off network
    Posted Dec 07, 2015 12:36 AM
    From what you have shared, looks fine. Need to troubleshoot further, for that, apporach TAC for assistance.
