"voip prioritization enable" gone in AOS 6.0 ?
  • 1.  "voip prioritization enable" gone in AOS 6.0 ?
    Posted Dec 12, 2011 10:58 AM
    We were using the command
    #voip prioritization enable          with AOS 5.0
    It seems that some of the options for the command #voip (like rtcp-inactivity or sip-midcall-req-timeout) are still available in AOS 6.0 with the command #voice
    But apparently the option "prioritization" is missing. Is there an equivalent, or the option is no longer available/useful in AOS 6.0 ?
    Nicolas.
  • 2.  RE: "voip prioritization enable" gone in AOS 6.0 ?
    Posted Dec 12, 2011 04:30 PM
    As of 6.x it is no longer there.  As long as Aruba has an ALG (application layer gateway) for a VOIP protocol, it will automatically classify and prioritize voice traffic, unless you are specifically blocking it.
    Protocols that the Aruba Controller is stateful for (according to p. 335 of the ArubaOS 6.1 user guide);
     dhcp
    dns
    ftp
    h323
    noe:
    rtsp
    sccp
    sip
    sips
    svp
    tftp
    vocera
