VOIP roaming over Wlan with an Android phone
  • 1.  VOIP roaming over Wlan with an Android phone
    Posted Jul 25, 2014 09:47 AM
    I work for a wireless network company. We are installing facilities with more than 50 or 100 ap.
    We need to find an Android phone or an Andoid software /setting who can do a good fast roaming for voip in a wlan environement with many AP.
    Someone can help me ?
  • 2.  RE: VOIP roaming over Wlan with an Android phone
    Posted Jul 25, 2014 02:59 PM
    You need a phone that supports 802.11r.
  • 3.  RE: VOIP roaming over Wlan with an Android phone
    Posted Jul 25, 2014 04:48 PM
    It's not only that. Some phones do the roaming better then other ones..
  • 4.  RE: VOIP roaming over Wlan with an Android phone
    Posted Jul 25, 2014 04:53 PM
    If this is mission critical voice, you should consider using VoWiFi phones.
  • 5.  RE: VOIP roaming over Wlan with an Android phone
    Posted Jul 25, 2014 11:49 PM
    We already use wlan ip phone with aruba infrastrcture. But the future market is with the smartphones.
  • 6.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 15, 2014 08:23 AM
    I'm also working for a telecommunications company located in Belgium. Most of our customers are small companies. Usually with 10 - 15 AP, we have enough AP to cover the customer site. That's why, we often work with Aruba IAP 105 which include a virtual controller.
    Yesterday, I have set up 12 Aruba IAP 105 at one of our customer site. I have created a Voice WLAN which works in the 5Ghz band of frequency. It works fine when I try to call with an Android phone. Unfortunately, when I start to move and when the Android phone must roam, I lose the communication because the android phone need about two seconds to register to the next AP.
    I'm almost sure that the problem comes from the phones but I would ask you if there are some parameters I can modify to speed up the roaming time? Is there an other parameter than "802.11r" that affects the roaming?
    Thanks in advance for your help :-)
  • 7.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 15, 2014 08:25 AM
    Do you have ClientMatch enabled?
  • 8.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 15, 2014 10:11 AM
    Hi Tim,
    Thanks for your fast response !
    I didn't know ClientMatch technology before your post. Thanks to you, I have just read an article about that technology. I think, it can help me. I will make some tests next week to see if it works better. Is there a particular configuration for ClientMatch (CM calculating interval, CM neighbor matching%, CM threshold)? Or the default configuration should work well?
    Do you have any other advice?
    I will also take a VoWLAN Phone (Unify OpenStage WL3) to test if I have the same roaming problem than with the Android phones.
    Thank you very much
  • 9.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 15, 2014 01:30 PM
    First of all clientmatch don't work of you use sip. We tried it and we saw that our network was spammed by clienatch retry. Clientmatch can be a solution but never in the voip over wlan. First of all with it you can't have a real roaming, the conversation will cut until you fine a better antenna. The biggest problem is that must of android phones aren't made ro roam on wlan but to stay sticky on one ap
    Envoyé de mon iPhone
  • 10.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 15, 2014 02:38 PM
    Have you done any tests with your iPhone? Does your iPhone manage roaming better on the same installation?
    Thanks for your point of view.
  • 11.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 16, 2014 05:57 AM
    It seems that the Apple producats are better roamer. I will try it asap.
  • 12.  RE: VOIP roaming over Wlan with an Android phone
    Posted Aug 27, 2014 02:33 PM
    I have made some tests on the same installation of about 12 APs with:
    • 1 Samsung Mini S3
    • 1 iPhone 4
    • 1 VoWiFi phone (OpenStage WL3)
    Here is the conclusion:
    I lose a lot of communications with the Android phone at the roamming time. The authentication time is indeed too long. I can observe a better behavior with ClientMatch enabled but I still lose the communication. As you told me earlier, the Android phone stay too long time on the same AP.
    The iOS phone works better than the Android one but unfortunately I can also observe some cut during the communication. I lose also the communication if I move too fast on the customer site. But the results are globally much better.
    With the VoWiFi phone, I never lose the communication.
    Most of our customers would unfortunately use their Android smartphone to make calls. It's a logical behavior. If you have any other ideas that can help the android smartphone to roam, don't hesitate to share them.
    Thanks in advance
  • 13.  RE: VOIP roaming over Wlan with an Android phone
    Posted Oct 13, 2014 05:30 PM
    I am not familiar with the backend VoIP server and you haven’t mentioned what Apple / Droid apps you tested. You have enabled QoS on the phone apps and you have checked for the correct QoS end-to-end (IAP to switch to VoIP server)?
    I've tested and seen some android softphones NOT enable QoS or fail to enable the correct VoIP QoS markings which could impact the packet priority settings and handling in the Aruba ALG. Quick packet capture over the air will show this.
    I found it good practice to minimize the "IP distance" between the WLAN VoIP client and the VoIP server. If you can provide IP addresses directly from the VoIP server subnet as the VoIP client registers when connected to the VoIP WLAN.
    Since it is a separate WLAN – SSID although not as secure WPA2-AES will provide a faster authentication when roaming. Unfortunately I did notice that WPA2-Enterprise did slow down the Droid CPU in early versions of the OS.
    When you have reviewed the packet capture you can open the advanced option in the IAP VoIP configuration to enable and set your WMM preferences.
    Of course all of this may not alleviate the roaming drops as it is the client that determines when to roam.
    I have used the Bria softphone (CounterPath SIP softphone) on my android with good results for local testing in my lab to my SIP server (I have the Apple version on an iPad as well) A web search may provide other Apple / Android dedicated VoIP apps you can download and test for a limited time (trial) to find the best for your environment and devices that the user base finds acceptable.
    Good Hunting
  • 14.  RE: VOIP roaming over Wlan with an Android phone
    Posted Oct 13, 2014 09:55 PM
    I have deployed VoWiFi in several hospitals, which are challenging environments, and here is what I have found:
    • Layer one and two is king.  Is the wireless networks designed and configured for the voice clients?  If not, you are going to have issues.
    • In every location is there a primary (stronger) access point AND secondary (weaker) access point broadcasting the voice SSID.
    • Do you have areas with large numbers of access points visible?  This can commonly "confuse" smartphones and tablets.
    • If the building is multi-level have you allowed for signal propagating from the floor(s) above/below.
    • During the design phase did you test every corridor and room with a wireless client having a voice call?  Did you walk both directions of the corridor? (west to east followed by east to west, for example)
    • Don't have access points in corridors or other large open plan areas.  If you need to do this then select antennas that will limit the signal propagation.  If you allow the signal to propagate across large areas then the wireless clients will become "sticky" and not want to roam.
    • Try to avoid any wireless feature that will delay roaming.  Some EAP types, Client Match, load balancing, etc can all cause issues.
    • Do packet captures to ensure that the upstream and downstream QoS settings are correct and there aren't an excessive amount of retries.  One capture should be beside the wireless client while the next should be beside the access point.
    Lastly, have you used Aruba's excellent Aruba Utilities application for Android?  It has an excellent wireless events area which shows when the Android device roamed.  I have walked up and down a large number of corridors with this application running.
