Voltage for IAP 225
  • 1.  Voltage for IAP 225
    Posted Jan 29, 2016 11:46 AM
    I would like to know the exact voltage required for an IAP-225 to work in normal mode.
    I know that it requires POE+ at power . But could you please let me know the voltage value required for the IAP-225 to work in normal mode ?
  • 2.  RE: Voltage for IAP 225
    Posted Jan 29, 2016 06:48 PM
    Voltage or Watts?  How are you powering the device?
  • 3.  RE: Voltage for IAP 225
    Posted Jan 30, 2016 10:22 AM
    12V / 15.6W power at the DC port, and ~48V for 802.3af or~54V for 802.3at using ~17.1W. General draw will be approx, as draw will be based on numbers of users, power of the radios, use of USB or second ethernet interface. There is no exact number in each case, as power can fluctuate at stratup and based on outside temperature as well, so you budget for the max draw always.
