VPN and source-nat
  • 1.  VPN and source-nat
    Posted Feb 02, 2012 10:20 AM
    I'm a total newbie with Aruba OS (less than 3 days).
    I'm trying to configure a 3400 controller to act as a VPN concentrator for distant users.
    I've got the following problem: I can't activate Source NAT in Advanced Services->VPN services->IPSEC
    Everytime i select "enable source nat" and give him a nat pool, when i come back on the same page, it stays desactivated
    ( "NO CHANGES WERE MADE")
    So, my distant users can establish the VPN, authenticate, they've got a private IP address  (pool-rap) assigned by the controller and so, can't communicate with other networks
    Any suggestion ? (and sorry if my question is trivial)
    o.p.
    Address Pools
    Pool Name Start Address End Address Actions
    pool-rap10.5.0.110.5.0.51
    Source NAT
    Enable Source NAT
    NAT Pooldynamic-srcnatpool-nat-vpn
    #3400
  • 2.  RE: VPN and source-nat
    Posted Feb 02, 2012 06:19 PM
    criecm.,
    What is the role that the distant users fall into? Does that role have the correct policies to pass traffic?
    show rights <user-role>
  • 3.  RE: VPN and source-nat
    Posted Feb 03, 2012 06:09 AM
    here are the informations requested but I really don't understand why i can't check "source nat" in the web interface ...
    (ArubaOS 6.1.1.1 and 6.1.2.6)
    thanks for your first response.
    (aw) #show rights UR-SAUTE-VLAN
    Derived Role = 'UR-SAUTE-VLAN'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Periodic reauthentication: Disabled
     ACL Number = 47/0
     Max Sessions = 65535
    access-list List
    Position  Name      Location
    1         allowall
    2         srcnat
    allowall
    Priority  Source  Destination  Service  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
    1         any     any          any      permit                           Low                                                           4
    2         any     any          any      permit                           Low                                                           6
    srcnat
    1         user    any          any      src-nat pool pool-nat-vpn                           Low                                                           4
    Expired Policies (due to time constraints) = 0
  • 4.  RE: VPN and source-nat
    Posted Feb 03, 2012 07:46 AM
     ACL Number = 47/0
    access-list List
    1         allowall
    2         srcnat
    allowall
    srcnat
    You need to remove the allowall.  All traffic is hitting that and never gets source-natted, as a result.
  • 5.  RE: VPN and source-nat
    Posted Feb 03, 2012 11:05 AM
    I've removed it and ... nothing, i still see packets coming from my private network 10.5.0.0, not being natted with the public controller IP address.
    Other questions:
    in the VPN configuration web interface, i have to define a local IP pool. that's where I've defined the 10.5.0.0/24 adresses
    and I've defined a NAT pool ( pool-nat-vpn: 10.6.0.0/24).
    As I can't enable source-nat, i can't assign this NAT pool to clients and so, clients got 10.5.0.0/24 address assigned and are never natted.
    -Could you please just try to define a nat-pool, assign it to the VPN conf and  enable source nat in the VPN conf GUI ?
    -do you know how could i do the same thing with the CLI ? (assign a nat pool and enable source nat in the VPN conf) ?
    thanks again
  • 6.  RE: VPN and source-nat
    Posted Feb 03, 2012 12:22 PM
    Other questions:
    thanks again
    The nat pool must be tied to a physical or logical ip interface that is already on the controller.  For example, if the egress interface of the controller is 10.5.0.1, I want a nat pool that is 10.5.0.1 to 10.5.0.1 to nat all traffic out of 10.5.0.1
  • 7.  RE: VPN and source-nat
    Posted Feb 17, 2012 08:41 AM
    sorry for this long silence, i was out of the office for a week.
    I've done source nat as you recommend it but i still don't undersdand why i can't check source-nat in the VPN config interface ...
    thanks again
  • 8.  RE: VPN and source-nat
    Posted Feb 17, 2012 08:53 AM
    thanks again
    That source-nat button is a legacy button when we only had a single configuration for VPN connectivity.  Your specific VPN configuration is now done using the role as was described.
  • 9.  RE: VPN and source-nat
    Posted Feb 17, 2012 02:04 PM
    This is what the source-NAT button does:
    user-role "default-vpn-role"
     session-acl "srcnat" position 1
    ip access-list session "srcnat"
     user any any src-nat pool "dynamic-srcnat" position 1
    If you're not using "default-vpn-role" then the UI feature won't work.  It's really just a convenience feature that inserts the "user any any src-nat" rule into a firewall policy - you can do the same thing manually, and it appears to me that you have to if you're using a custom role.
