Higher Education
last person joined: 24 days ago
Got questions on how to enable mobility in education? Submit them here!
VPN Concentrator Advice...
  • 1.  VPN Concentrator Advice...
    Posted Aug 20, 2015 09:03 AM
    After some upgrades, SSID consolidation, Dot1x convergence and new 7200 controller integration, I now have a left over 3200XM controller. I would like to turn it into a dedicated VPN concentrator. So my question is: Should I leave it as a stand alone master or should I go ahead and make it a local. What are the pros/cons either way?
    Any advice is appreciated!
  • 2.  RE: VPN Concentrator Advice...
    Posted Aug 20, 2015 09:18 AM
    I would leave it standalone so you don't have to worry about upgrading code
    when you upgrade your wireless environment. Are you using this for
    site-to-site or clients (VIA)?
  • 3.  RE: VPN Concentrator Advice...
    Posted Aug 20, 2015 09:22 AM
    Hi Tim!
    I would be strictly clients and in the future maybe some RAPs. That would be it. Seemed like a good way to make use of an older controller.
  • 4.  RE: VPN Concentrator Advice...
    Posted Aug 20, 2015 10:21 AM
    Also, if you have AirWave, you can leave it as a standalone but sync the config from your main environment.
    Tim
