VPN S2S Tunnel Question
  • 1.  VPN S2S Tunnel Question
    Posted Mar 29, 2017 10:58 AM
    Hi together,
    i have to ask some details about this ASE
    ASE s2s Tunnel
    My Task is to configure a active (live) controller so i have to be sure what iam doing :-)
    We have a moving 7005 with dyn Internet IP and i want to connect that controller with VPN to our corporate.
    So the ASE is fine but i am not really happy about the explanation of src-net %dyn_src_network% %dyn_src_mask%
    dst-net %dyn_dst_network% %dyn_dst_mask%
    Also the guide didnt explain the meaning.
    So in my case for Example lets say i have a 192.168.0.0/24 on my moving controller. And f.e. on the static VPN "Hub" i have a 10.0.0.0/16 and one 172.16.0.0/24.
    Goal is reached when 10.0.0.0/16 and 172.16.0.0/24 can reach the 192.168.0.0/24 and vice versa.
    What do i need here as src and dst-net on the hub and on the moving.
    I only know the cisco method with ACLs and tunnel IFs so maybe thats the cause why i am a little bit confused :-)
    Thanks in advance for a explanation!
  • 2.  RE: VPN S2S Tunnel Question
    Posted Mar 30, 2017 02:59 AM
    Any suggestions?
  • 3.  RE: VPN S2S Tunnel Question
    Posted Apr 06, 2017 04:22 AM
    Answer:
    This is really the "ACL" which Network Adresses can use the tunnel to which destinations. Currently i don't know why you also can add a route ACL on top.
