VPN to ClearPass
  • 1.  VPN to ClearPass
    Posted Mar 07, 2013 05:20 AM
    Is it possible to open a VPN between the VC of an IAP105 to my ClearPass Guest server ? IAPs are in a remote place and the server in a datacenter.
    Dimitri
  • 2.  RE: VPN to ClearPass
    Posted Mar 07, 2013 06:50 AM
    ClearPass only allows GRE tunneling, which does not survive NAT, so it should NOT used on the internet.
    You can tunnel IAP using IPSEC to a controller, however...
  • 3.  RE: VPN to ClearPass
    Posted Mar 07, 2013 06:54 AM
    Ok IPSEC IAP-Controller and then access to the ClearPass server.
    Thanks.
    Dimitri
