Is it possible to vpn to a local controller? I'm trying configure the IPSEC options on the local, but it is all greyed out. Does this mean that it must be configured on the master? If so, is it possible to have the VPN session terminate to the local rather than the master?
You can terminate VPN connections on the local controller.
You must configure all the VPN parameters on the master, EXCEPT for the VPN pool, which must be configured on the local.
