VRF support for gateways
  • 1.  VRF support for gateways
    Posted Oct 22, 2020 10:55 AM
    Seems that the previous topic was locked as it was already started in 2013
    But I really would like to see VRF support for Aruba gateways in the future. We have customers using overlapping IP addresses so VRF support would be needed. And hopefully in the very near future...
    Otherwise in 2020 it seems silly to get separate hardware gateway to have different routing tables.
  • 2.  RE: VRF support for gateways
    Posted Oct 22, 2020 11:03 AM
    You should look at the innovation page and see if there is already a request:
    https://innovate.arubanetworks.com/ideas/search?utf8=%E2%9C%93&query=vrf
  • 3.  RE: VRF support for gateways
    Posted Oct 22, 2020 11:05 AM
    As it's been requested since 2013 I guess we should use every means possible
    Edit: not sure if I had account there but I'm getting a weird SAML error message when trying to log in...
    Edit2: there is no password reset option
  • 4.  RE: VRF support for gateways
    Posted Oct 25, 2020 04:31 AM
    Seems that there is a innovate idea: https://innovate.arubanetworks.com/ideas/WLAN-I-1395
    Only 28 votes though. VRF support is something I would consider a basic requirement. So I guess not many people see VRF as a requirement in Aruba world
    In our case we probably need to just get 7010 controllers for every customer we need to separate, which seems pretty silly in 2020 with all the virtualization and cloud stuff happening elsewhere.
