Network Management
VRRP
  • 1.  VRRP
    Posted Dec 12, 2021 09:32 PM
    Hi all,
    Configured vrrp on two core switches (layer 3). In our environment, all the access switches are layer 2 switches..
    Core-Switch1
    vlan 5
    ip address 192.168.1.1/24
    vrrp vrid 5
    virtual-ip address 192.168.1.100
    priority 254
    enable
    and
    Core-Switch2
    vlan 5
    ip address 192.168.1.2/24
    vrrp vrid 5
    enable
    One of the vlan..configuration is like this..
    On the access switch, default gateway is set to only core 1
    ip default-gateway <core1_IP_Address>
    Lets say for instance, if core 1 is down, then I need to tell access switch to route the traffic to Core2..
    Question here,
    Can I configure two default -gateways ? using matric ?
    I don't think we can configure
    ip route 0.0.0.0 0.0.0.0 <Core1>
    ip route 0.0.0.0 0.0.0.0 <Core2> 20
    Please advise.
    Many Thanks,
    Binod
    Binod Ranabhat
  • 2.  RE: VRRP
    Posted Dec 13, 2021 07:24 AM
    Hi Binod, how are you?
    VRRP was designed for you to use as a gateway redundancy, so it is advisable to point the virtual IP address of the VLAN and VRRP will automatically balance the physical address of the box interface and the virtual IP.
    So there is no need to create static routes, let VRRP work this automatically.
    Leonardo Xavier
