VRRP Active standby V8 Controller 72xx
  • 1.  VRRP Active standby V8 Controller 72xx
    Posted May 04, 2021 12:10 PM
    Hello
    i try to connect 2 controllers 72xx with vrrp protocol in mode active / standby, it is possible?
    controllers firmware version is: 8.x
    if dont, what can i do for sinchronize both controllers and give basic failover?
    thanks
    reneJ
  • 2.  RE: VRRP Active standby V8 Controller 72xx
    Posted May 04, 2021 06:53 PM
    With AOS 8.x the correct method would be Controller Clustering, which would give you the synchronized config and automatic failover. If you don't want the clustering setup, and just true active/standby, you could just configure VRRP between them, and use the VRRP IP for the APs to connect to the controller..
    Here is a video on setting up Clustering, but if you skip to about 9:20 it goes over just the VRRP redundancy config.
    https://www.youtube.com/watch?v=nbhRBD6VEzA
  • 3.  RE: VRRP Active standby V8 Controller 72xx
    MVP GURU
    Posted May 04, 2021 09:12 PM
    Just keep in mind, clustering requires the controllers to be managed by a Mobility Conductor.
    Dustin Burns
