VRRP Active standby V8 Controller 72xx
  • 1.  VRRP Active standby V8 Controller 72xx
    Posted May 04, 2021 12:10 PM
    Hello
    I try to connect 2 controllers 72xx with vrrp protocol in mode active / standby, it is possible?
    controllers firmware version is: 8.x
    if dont, what can i do for synchronize both controllers and give basic failover?
    reneJ
  • 2.  RE: VRRP Active standby V8 Controller 72xx
    Posted May 06, 2021 02:18 AM
    Hi
    It is possible. You need to initial controller as standalone and everything else you configure like as v6 - VRRP, master redundancy.
    Regards
    Piotr Filip
    ACEX#41/ACCX/ACDX/ACMX/CWNA/CWSP
