Wired Intelligent Edge
VRRP Between different models of switches
  • 1.  VRRP Between different models of switches
    Posted Jul 07, 2021 02:39 PM
    Its possible?
    If its possible, there could be any issue if i build it like that? or any kind of consideration i need for it? besides  that it should hold all the traffic that the active l3 switch is handling
    Cheers
    Carlos
    Carlos De La Rosa
  • 2.  RE: VRRP Between different models of switches
    Posted Jul 08, 2021 03:36 AM
    VRRP is a standard so it should work between 2 different brand. Some specific might be:
    -timers where minimum timers may vary between switches.
    - supported authentication algorithms
    Vincent Giles
