Hi there, hopefully someone can help me with this, I'm thinking I'm just off on something simple.
I have two Procurve E3500yl switches setup to do routing. I have 5 VLAN's setup on each.
VLAN 9 10.1.2.x/24
VLAN 11 10.2.14.x/24
VLAN 31 10.2.16.x/24
VLAN 61 10.2.18.x/24
VLAN 121 10.2.150.x/24
VLAN 9 is connected to a single direct connection to our other datacenter on Switch 1 Port 1 and is configured with an IP of 10.1.2.1. The connection on the other end at the datacenter is 10.1.2.2. Switch 2 Port 1 is configured with an IP of 10.1.2.5 on the same VLAN, but has no cable connected to it. I have a cable connecting the 2 switches on Port 4. All VLANs which need to reach the other datacentre are untagged on their own ports and tagged on Port 1 and Port 4.
Each system which is connected has as it's gateway the IP address of the VLAN port on Switch 1, (ex: 10.2.16.3). The same port on Switch 2 would be 10.2.16.4.
I have created a VRRP group for each VLAN with Switch 1 as the owner and Switch 2 as the backup and the IP set as the same as Switch 1. VRRP VRID 9 is configured on Switch 1 and Switch 2 with an ip of 10.1.2.1.
My goal is to set it so that if Switch 1 were to fail, we would simply have to move the single wire of the direct connection to the datacenter from Switch 1 Port 1 to Switch 2 Port 1, with no reconfiguration of gateways on servers. Based on what I've read, VRRP should be able to acheive this.
So, I picked up a procurve 2510-24Gconfigured 2 VLAN's on it with no IP configuration. Ports 1-12 are on VLAN 51 and 13-24 are on VLAN 52. I also turned on spanning tree protocol on my two E3500's per the documentation.
So, what I tried is this: I took the cable from the direct connection and plugged it into port 2 on my 2510 and I took a wire from Switch 1 Port 1 and and Switch 2 Port 1 and plugged them into port's 3 and 4 respectively on my 2510. Everything breaks. I lose all access to my E3500 switches, as well as all access to the other datacentre.
Hopefully I've given enough information here to be useful, can anyone make any suggestions? If you need more info, just let me know.
#VRRP
