In the CLi
Execute the following CLI commands on both Mobility Masters:
(MM-Primary) [mynode] (config) #vrrp <id>
(MM-Primary) ^[mynode] (config-submode)#ip address <ip addr>
(MM-Primary) ^[mynode] (config-submode)#vlan <id>
(MM-Primary) ^[mynode] (config-submode)#description <string>
(MM-Primary) ^[mynode] (config-submode)#priority <level>
(MM-Primary) ^[mynode] (config-submode)#no shutdown
The following sample CLI commands configure virtual router 10 on the initially-preferred master:
(MM-Primary) [mynode] (config) #vrrp 10
(MM-Primary) ^[mynode] (config-submode)#ip address 192.168.10.245
(MM-Primary) ^[mynode] (config-submode)#vlan 1
(MM-Primary) ^[mynode] (config-submode)#description "Preferred-Master"
(MM-Primary) ^[mynode] (config-submode)#priority 200
The following sample is the corresponding VRRP configuration for the backup Mobility Master:
(MM-Backup) [mynode] (config) #vrrp 10
(MM-Backup) ^[mynode] (config-submode)#ip address 192.168.10.245
(MM-Backup) ^[mynode] (config-submode)#vlan 1
(MM-Backup) ^[mynode] (config-submode)#description "Backup-Master"
(MM-Backup) ^[mynode] (config-submode)#priority 100
(MM-Backup) ^[mynode] (config-submode)#no shutdown
Verifying VRRP Configuration
Execute the following CLI command on the Mobility Master (both primary and backup) to verify the VRRP configuration:
(MM-Primary) [mynode] #show vrrp <id>
The following output is displayed on the primary Mobility Master:
(MM-Primary) [mynode] #show vrrp 10
Virtual Router 10:
Description
Admin State UP, VR State MASTER
IP Address 192.168.10.245, MAC Address 00:00:5e:00:01:34, vlan 1
Priority 200, Advertisement 1 sec, Preemption Disable Delay 0
Auth type NONE ********
tracking is not enabled
The following output is displayed on the backup Mobility Master:
(MM-Backup) [mynode] #show vrrp 10
Virtual Router 10:
Description
Admin State UP, VR State BACKUP
Priority 100, Advertisement 1 sec, Preemption Disable Delay 0
The following sample commands configure Master redundancy on the primary Mobility Master:
(MM-Primary) [mynode] (config) #master-redundancy
(MM-Primary) [mynode] (config-submode)#master-vrrp 10
(MM-Primary) ^[mynode] (config-submode)#peer-ip-address 192.168.10.244 ipsec aruba123
(MM-Primary) ^[mynode] (config) #write memory
The following sample is a Master redundancy configuration on the backup Mobility Master:
(MM-Backup) [mynode] (config) #master-redundancy
(MM-Backup) [mynode] (config-submode)#master-vrrp 10
(MM-Backup) ^[mynode] (config-submode)#peer-ip-address 192.168.10.243 ipsec aruba123
(MM-Backup) ^[mynode] (config) #write memory
