Aruba Apps
last person joined: 13 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
VRRP CONFIGURATION ON ARUBA CX SWITCH
This thread has been viewed 21 times
  • 1.  VRRP CONFIGURATION ON ARUBA CX SWITCH
    Posted Dec 29, 2022 09:44 PM
    Hi team,
    We have two 6400 series switches. We want to configure vrrp between vlan for common gateway for users.
    Example
    On switch 1 :
    Sw1(config)# interface vlan 10
    Ip address 192.168.1.2/24
    Vrrp 1 address 192.168.1.1 primary
    Vrrp priority 150
    And on switch 2:
    Sw2( config)# interface vlan 10
    Ip address 192.168.1.3/24
    Vrrp 1 address 192.168.1.1 secondry or primary?
    I am confused about this primary and secondary.
    What does it mean. Should I configure primary on both the switches for vrrp ip or primary on master switch only.
  • 2.  RE: VRRP CONFIGURATION ON ARUBA CX SWITCH
    Posted Jan 01, 2023 05:48 AM
    VRRP determines the role (primary or secondary) of each device in a VRRP group by priority.
    A device with a higher priority is more likely to become the primary. A greater number represents a higher priority.
    Default Priority is 100
    Sample Config:
    SW1:
    vlan 128
    tagged 3-4
    ip address x.x.x.2 255.255.255.0
    vrrp vrid 10
    virtual-ip-address x.x.x.1
    priority 190
    enable
    exit
    exit
    SW2:
    vlan 128
    tagged 3-4
    ip address x.x.x.3 255.255.255.0
    vrrp vrid 10
    enable
    exit
    exit
    Since you are having 6400, you can use VSX for High availability.
    Kapildev Erampu
    Systems Engineer, ACEX#94
    Aruba, a Hewlett Packard Enterprise company
    Any opinions expressed here are solely my own and not necessarily that of HPE
  • 3.  RE: VRRP CONFIGURATION ON ARUBA CX SWITCH
    Posted Jan 02, 2023 12:53 AM
    But in Aruba CX 6400 ,we have to choose primary or secondary otherwise it shows command is incomplete.
