last person joined: 11 hours ago
VRRP issues
  • 1.  VRRP issues
    Posted Mar 21, 2013 06:07 AM
    Hi all,
    I'm currently expierincing some vrrp issues where the backup vrrp takes over of the master. In the logs i'm seeing that the master is sending advertisements, but I'm seeing rather strange messages on the backup:
    My theory is: VRRP is just working fine, untill it receives an other VRRP request, and because of that, the preempt starts. Am I right about this?
    Mar 13 07:57:52 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1025 Sequence number 3142
    Mar 13 07:57:52 fpapps[1687]: <313328> <WARN> |fpapps| vrrp: vrid "147" - VRRP state transitioned from MASTER to BACKUP
    Mar 13 07:57:52 fpapps[1687]: <306502> <DBUG> |fpapps| Publish service 'VRRP_STATE', object len 20
    Mar 13 07:57:52 fpapps[1687]: <313330> <INFO> |fpapps| Sending Role change event to CFGM
    Mar 13 07:57:52 fpapps[1687]: <313332> <WARN> |fpapps| VRRP: vrid "147"(Master) - Received VRRP Advertisement with HIGHER PRIORITY (110) from 172.16.4.8 Mar 13 07:57:52 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1025 Sequence number 3143 Mar 13 07:57:52 fpapps[1687]: <313328> <WARN> |fpapps| vrrp: vrid "148" - VRRP state transitioned from MASTER to BACKUP Mar 13 07:57:52 fpapps[1687]: <306502> <DBUG> |fpapps| Publish service 'VRRP_STATE', object len 20 Mar 13 07:57:52 fpapps[1687]: <313332> <WARN> |fpapps| VRRP: vrid "148"(Master) - Received VRRP Advertisement with HIGHER PRIORITY (110) from 10.160.5.208 Mar 13 07:57:52 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1025 Sequence number 3144 Mar 13 07:57:52 fpapps[1687]: <313328> <WARN> |fpapps| vrrp: vrid "222" - VRRP state transitioned from MASTER to BACKUP Mar 13 07:57:52 fpapps[1687]: <306502> <DBUG> |fpapps| Publish service 'VRRP_STATE', object len 20 Mar 13 07:57:52 fpapps[1687]: <313332> <WARN> |fpapps| VRRP: vrid "222"(Master) - Received VRRP Advertisement with HIGHER PRIORITY (110) from x.x.x.x Mar 13 07:57:52 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1025 Sequence number 3145 13 07:57:53 fpapps[1579]: <399814> <DBUG> |fpapps| Received a Switch IP Request from 8224 Mar 13 07:57:53 fpapps[1579]: <399814> <DBUG> |fpapps| Received a Switch IPv6 Request from 8224 Mar 13 07:57:53 fpapps[1579]: <399814> <DBUG> |fpapps| Received a Switch IP Request from 8224 Mar 13 07:57:53 fpapps[1579]: <399814> <DBUG> |fpapps| Received a Switch IPv6 Request from 8224 Mar 13 07:57:53 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 7005 DestPtNm 8224 DestIp 127.0.0.1 PckTy 1025 Sequence number 3146 Mar 13 07:57:53 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5b000 err 0 MsgCode 7005 DestPtNm 8224 DestIp 127.0.0.1 PckTy 1025 Sequence number 3147 Mar 13 07:58:19 fpapps[1579]: <399835> <DBUG> |fpapps| Time taken for activation of configuration 0 sec and 195 microseconds. Mar 13 07:58:19 fpapps[1579]: <306504> <DBUG> |fpapps| received subscription message from 8214 for service 'tunnel' Mar 13 07:58:19 fpapps[1579]: <306504> <DBUG> |fpapps| received subscription message from 8214 for service 'VRRP' Mar 13 07:58:19 fpapps[1579]: <306503> <DBUG> |fpapps| Publish service 'VRRP', object len 12 to module 8214 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3148 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5b000 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3149 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5b800 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3150 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5c000 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3151 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x13773ad4 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3152 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x13772744 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3153 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x13772854 err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3154 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x13772eac err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3155 Mar 13 07:58:19 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x13772fbc err 0 MsgCode 11000 DestPtNm 8214 DestIp 127.0.0.1 PckTy 1025 Sequence number 3156 Mar 13 07:59:21 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 222 Mar 13 07:59:30 fpapps[1687]: <313509> <DBUG> |fpapps| VRRP Preempt delay timer expired for VRID 222 Mar 13 07:59:30 fpapps[1687]: <313329> <DBUG> |fpapps| VRRP: Sending Advertisement for vrid 222 Mar 13 07:59:30 fpapps[1687]: <313328> <WARN> |fpapps| vrrp: vrid "222" - VRRP state transitioned from BACKUP to MASTER Mar 13 07:59:30 fpapps[1687]: <306502> <DBUG> |fpapps| Publish service 'VRRP_STATE', object len 20 Mar 13 07:59:31 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1025 Sequence number 3157 Mar 13 07:59:31 fpapps[1687]: <313328> <WARN> |fpapps| vrrp: vrid "222" - VRRP state transitioned from MASTER to BACKUP Mar 13 07:59:31 fpapps[1687]: <306502> <DBUG> |fpapps| Publish service 'VRRP_STATE', object len 20 Mar 13 07:59:31 fpapps[1687]: <313332> <WARN> |fpapps| VRRP: vrid "222"(Master) - Received VRRP Advertisement with HIGHER PRIORITY (110) from x.x.x.x Mar 13 07:59:32 fpapps[1579]: <399815> <INFO> |fpapps| fpappsCB: msgPvtPart 0x12a5a800 err 0 MsgCode 11000 DestPtNm 8378 DestIp 127.0.0.1 PckTy 1025 Sequence number 3158 Mar 13 08:00:32 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 147 Mar 13 08:00:32 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 148 Mar 13 08:00:32 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 222 Mar 13 08:00:33 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 62 Mar 13 08:00:33 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 63 Mar 13 08:00:33 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 65 Mar 13 08:00:33 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 146 Mar 13 08:00:34 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 60 Mar 13 08:00:34 fpapps[1687]: <313508> <DBUG> |fpapps| Started the VRRP preempt delay timer for VRID 61 Mar 13 08:00:42 fpapps[1687]: <313509> <DBUG> |fpapps| VRRP Preempt delay timer expired for VRID 147 Mar 13 08:00:42 fpapps[1687]: <313329> <DBUG> |fpapps| VRRP: Sending Advertisement for vrid 147 Mar 13 08:00:42 fpapps[1687]: <313328> <WARN> |fpapps| vrrp: vrid "147" - VRRP state transitioned from BACKUP to MASTER
    #7005
  • 2.  RE: VRRP issues
    Posted Mar 21, 2013 10:18 AM
    Thanks for the quick reply!
    1. Spanningtree is disabled
    2. Connected to a L3 switch
    3. Connected via a trunk
    4. Preempt is enabled on all vrrp's with a 10sec timer. How will the failover system work if I disable preempt on the backup?
    5. Priority is set-up correctly.
  • 3.  RE: VRRP issues
    Posted Mar 21, 2013 09:54 AM
    How are the controllers physically connected to your infrastructure?  Are they connected via trunk?  Do you use spanning tree?
    What is the output of "show vrrp XX statistics" on both sides?
    • Take a small tip  - check if you have preempt line in both controllers.
    • delete the preeempt line (using cli) from the 2nd (master standby) one.
    • Also be sure to  choose higher priority to your master. (example: master = 120 , s.b master = 100)
    update me - and i will continue to assit you.
    me
  • 4.  RE: VRRP issues
    Posted Mar 21, 2013 10:21 AM
    yep
    check it
    leave preempt only on your master and not on your standby master,and check it.
    me
  • 5.  RE: VRRP issues
    Posted Mar 21, 2013 10:44 AM
    Thanks! I'll be able to try it out tomorrow, I'll keep you posted!
  • 6.  RE: VRRP issues
    Posted Mar 27, 2013 02:54 AM
    Turned preempt off on the backup controller. Also turned BCMC optimization on, on the vlan interfaces where VRRP runs. This resulted that the VRRP issues dissapeared. Howver, when an AP rebooted, it wouldn't come up at all (none of the AP's that rebooted).
